Topic: American Audio VMS2 & VDJ8
VDJ8 recognizes my VMS2 but the cross fader only works properly with the left deck. I cannot listen to my right deck cue in the headphones and once the cross fader is pulled all the way right the sound on that right deck (2) dissappears. CRAZY!! It works perfectly with VDJ7.
geposted Tue 17 Jun 14 @ 10:31 pm
Do you use your V7 Mapping or the native V8 one ?
VMS2 & VDJ 8. Downloaded and installed today 6/30. I am having the same problem. Cross fader to the left plays let deck. Cross fader to the right right deck nothing.
Apparently, for both, the Audio Setup is incorrect. The "special" button in the AUDIO tab of Config, should offer a Sound setup with deck 1 and deck 2 (External mixer setup).
