Forum: Old versions
Topic: Sort tracks in virtual folder
Is there a way to sort files in a virtual folder other than by tag headings. I want to create a folder with files from say a decade and sort them by popularity much like a playlist.
Or do I have to use playlists for that?
geposted Wed 18 Jun 14 @ 11:05 am
How do you measure and record popularity? Can't you just use one of the fields
As I thought. I'll have to use play lists to keep them in order. It's kind of like a top 40 list in descending order that I'm after.
As loco says, you could use (for example) the Track tag field to enter a chart position and then sort via that field in the VDJ browser.
Alternatively (if you already use Track for CD track numbers) you could create your own unique "string", enter it into Field1 (aka User 1) and sort by that.
Example: use the string 80schart and append the chart pos e.g. 80schart01, 80schart02 and so on.
Thanks groovindj. I'll look into that
Cheers guys I guess it was a bit of a daft question on reflection :-)
