Forum: Old versions
Topic: MIDI setup to modify "beats" under sampler
I got my Maschine 2 to work as a MIDI controller to VDJ8. So, now I can pull up a sampler bank and have pad 1-12 turn on/off samples... but what I can't figure out is how to tell the system to modify the beats variable... Can anyone confirm that this is possible?? maybe it not midi control-able?? If so, what do I do..
thanks,
joe...
geposted Fri 20 Jun 14 @ 2:05 am
It is possible abandon this thread I will help you in the old thread, it will make it easier for other people to follow.
Sounds good. I will update later with a link to the other thread.
the actions are..
sampler_loop +1
sampler_loop -1
You will need build 1845
Enable the setting getBetabuilds from config->options (if not already) as currently this build is not public
