I have a very minor problem on the default skin the two small video panels i.e. deck 1 & deck 2 (centre screen) do not display the video's correctly..... Best way to describle this is like you've not tuned your TV correctly onto the station and the horizontal lines you get just before the picture comes up strong.
I had this before, But can't remember if it was HW Acceleration or SkinFPS being too low or something else....? Any one else seen or had this and know how to fix ?
The 3rd video panel (main one) displays fine......, Just the two smaller ones!!!
Thanks in advance
Thanks in advance
geposted Sun 22 Jun 14 @ 4:24 am
I have the same problem with VJ8..... did not have problem with VJ7.
I have tried different skins and same issue.
Computer Laptop specs:
I7 - 3610 processor
16GB 1600MHZ DDR3 RAM
Nvidia GTX675 4GB GDDR5 Video Card
120 GB Solid State main hard drive.
750 GB extra internal drive.
5 USB ports (3 - 3.0 USB)
3 TB External Hard drive using USB 3.0.
I7 - 3610 processor
geposted Sun 22 Jun 14 @ 1:49 pm
same here...
geposted Sun 22 Jun 14 @ 3:08 pm
I tried VJ8 on my other laptop computer running Windows 7 64bit and ATI video card and videos are playing fine.... 3 hour test
Laptop with Windows 8.1 and Nvidia card is having problems.
Dale
Dale
geposted Sun 22 Jun 14 @ 8:56 pm
Can you please explain this, a little better, because I don't see or understand what you are talking about.
geposted Sun 22 Jun 14 @ 9:09 pm
Seems that this is related to specific NVidia cards (or driver version maybe) only.
I have a Nvidia Gt740M and don't have this problems.
geposted Mon 23 Jun 14 @ 6:34 am
If you have enabled 'videoFullScreen', please try to set it to 0 again.
geposted Mon 23 Jun 14 @ 8:41 am
