Forum: Old versions
Topic: DEFAULT
HELLO EVERYONE
I would like to set the "effect LoopRoll" default on 2 beats with 80% of strenght
but i don't understand how to use the numbers in the advanced settings :
16.000000, 0.250000
can someone explain me how it works?
i've also note that one the effect on the rest and if for example i put a song on the same deck in without desactivate the effect it will trigger at the same time as the song before :-S
geposted Sun 22 Jun 14 @ 7:15 am
These are two different loop rolls.
One is an effect and the other just an option for loop.
They have different settings.
Ok but i just want to know how to set the effect option by default
The values for any effect parameters are saved in an ini file inside the Plugins folder, once you use them for the first time. So, if you launch VirtualDJ, adjust the effect parameters on one deck, and close the software, next time you launch, the parameters should have the same values.
However, if you change them during a session, e.g. a knob on your controller change the strength or the length, next time you launch , the parameters will have those values as initial.
also keep in mind that the actions loop_roll x , automatically put strength to 100%, so in your case, you will need to use effect_active 'loop Roll' on/off
