i cant get the cut effect to come up on my select list. the autocut will. any ideas
geposted Sun 22 Jun 14 @ 7:08 pm
i believe it is not compatible with vdj8 as mine doesn't come up either
geposted Sun 22 Jun 14 @ 7:44 pm
What did it do?
geposted Sun 22 Jun 14 @ 10:15 pm
Also have you tried renaming the dll, I think Atomix blocked the names of V7 effects that don't work perfectly with V8, their way of saying no longer supported , I got V7s overloop backspin and brake working by renaming them, Overloop won't work with the beat grid running, the other 2 don't auto off when the effect has finished but I'll take the risk and have a fire extinguisher handy if things go really wrong.
geposted Sun 22 Jun 14 @ 11:56 pm
well that bites but i will you the autocut. cant have it all.
geposted Mon 23 Jun 14 @ 8:13 pm
How do you rename the dll? I don't seem to have an option to do this?
geposted Mon 06 Oct 14 @ 5:24 pm
Find the cut.dll in windows (VDJ folder/Soundeffects or something like that) and rename it like you would any other windows file, I'm told cut1.dll works
geposted Mon 06 Oct 14 @ 7:44 pm
Thanks for the help. Yes it worked and the cut effect shows in VDJ8 but it does not work very well, sounds distorted. Like you say, they blocked it for a reason.
geposted Mon 06 Oct 14 @ 9:39 pm
please can someone send me the transform/cut effect for virtual dj8 through my email EMAIL REMOVED
[Mod] Sorry, sharing personal contact information is only permitted with a license.
geposted Wed 12 Sep 18 @ 4:00 pm
The cut effect is included by default in newer releases of VDJ8. If you don't have it, simply upgrade your VDJ
geposted Wed 12 Sep 18 @ 6:28 pm
