I am using 1855 but need to check on older version maybe back to 1828. Where can I get the older versions?
geposted Thu 26 Jun 14 @ 3:31 pm
Unless you saved them - you can only get the current beta and the current public release.
geposted Thu 26 Jun 14 @ 4:05 pm
After about 10 or so I started cleaning up.
Silly not to be able to go back and cross check.
geposted Thu 26 Jun 14 @ 4:18 pm
a new fault, in this version, to raise and lower the earpiece volume, up to 30 percent, frying makes noise ...
geposted Thu 26 Jun 14 @ 5:23 pm
also would be nice that master volumes, and headset, move the skin, as you move the controller ...
geposted Thu 26 Jun 14 @ 5:25 pm
Which controller?
geposted Thu 26 Jun 14 @ 11:40 pm
pioneer ergo black limited edition
geposted Fri 27 Jun 14 @ 6:13 am
Headphone dial on skin is working when adjusted on standard ergo also I would rather the master on controller not be linked to skin master thanks
geposted Fri 27 Jun 14 @ 7:15 am
Most of you have probably missed the very first thread of this forum..
https://virtualdj.com/forums/188979/Beta_Builds_Regression_Bugs/Welcome_to_the_beta_builds_forum.html
If you find "normal" bugs, that were already present in the previous builds, please use the regular VirtualDJ 8 forum to report them.
Please post only regression bugs here
geposted Fri 27 Jun 14 @ 3:16 pm
Hi,
I don't see the beta version in my download section. How can download it?
Kevin
Kevin
geposted Fri 27 Jun 14 @ 3:55 pm
Config -> Options -> search advanced:
getBetaBuilds -> YES
geposted Fri 27 Jun 14 @ 4:30 pm
to enter sound settings closes unexpectedly
geposted Fri 27 Jun 14 @ 5:46 pm
Ok I ran this update and I love it! The Mac version seems a lot stable now! Good work!
geposted Sat 28 Jun 14 @ 5:38 am
previewplayer have many issue, click on playing song and it stops
Shift + CUE on left works
Shift + CUE right don´t work with vms2 SHIFT_PFL "deck active select"
vinylbrake effekt start always with 1855 with older Build it works fine. effect "vinylbrake" active
geposted Sat 28 Jun 14 @ 8:24 am
This update reverted all my Sampler sound clips in Version 7 to default samples. all my sampler bank settings was lost after update.
geposted Sat 28 Jun 14 @ 4:39 pm
good news, work 8 hours with this release, non-stop, and do not show absolutely no fault, the only drama and I noticed, is that having multiple databases, when tracks are loaded, has 3-4 second freeze this means it does not support multiple databases.
and headphones, hear with frying, it is also annoying ...
Greetings ...
Greetings ...
geposted Sun 29 Jun 14 @ 2:35 pm
I had a crash with auto restart with this build -> no internet... do you get the crash report?
geposted Sun 29 Jun 14 @ 2:55 pm
No, the crash didnt get uploaded. You were offline when this happened ? Can you reproduce it ?
geposted Sun 29 Jun 14 @ 5:09 pm
I demand as also the other users, which are arranged cuts Equalizer
geposted Sun 29 Jun 14 @ 6:40 pm
I read this three times, and still don't understand. Also, what is frying?
geposted Sun 29 Jun 14 @ 6:56 pm
