Topic: VMS4.1 issues
I have a VMS4.1 .Using windows 8.1 and VDJ 8. It Worked fine for the first 20 minutes then started acting problematic. The left deck is not responding well.It jumps beats and doesn't cue right.It also does a strange thing with video now. When I load channel 2 it works then when I load channel 3 it takes over channel 2 and video switches to channel 3. I have settings on mixer correct. When I used 7.4 had no problems.Tried advice given still no fix. Treid and run in 4 mode that didn't work. Also it doesn't run DVS properly.Pitch goes backwards while playing.Using serato CV2.I tdoesn't recognize SL1 box so I tried the internal soundcard
geposted Tue 24 Jun 14 @ 1:18 pm
