Forum: Old versions
Topic: Numark Mixtrack Quad.
Does anyone know how to address the RGB LEDS in the drum pads to make VDJ able to change the colour.
I know VDJ can change the colours as mapping them to different functions causes the colours to change.
The Other mapping I am looking at is the Jog Whell LEDS I would like to Flash near the end of the song but still keep the rotating LEDs until the song is near end then Blink.
geposted Tue 24 Jun 14 @ 2:05 pm
We will update the Mixtrack Quad files shortly to support the RGB leds for version 8 sampler actions.
As for the ring led flashing near the end of the track, i think its already implemented, but may nto work as expected.
The default action is ..
loaded ? songpos_remain 30000ms ? get beat_bar : off : off
you may try to change that as ..
loaded ? songpos_remain 30000ms ? blink ? get constant 0.9 : get constant 0.0 : off : off
Just been playing around with the updated VDJ8 vary happy and now have the drum pads as I want them. Also the Flashing jog rings are much better now.
Just one question. If I with to have the jogs flash from 45sec remain normally and then say flash 500ms from 20sec remain how do I do it?
LED_JOG_ON : loaded ? songpos_remain 20000ms ? blink 300ms ? get_constant 0.01 : get_constant : songpos_remain 45000ms ? blink 600ms ? get_constant 0.01 : get_constant : nothing : get_constant
LED_JOG: songpos_remain 45000ms ? off : get rotation
sorry for late reply, thanks for that. Works a treat.
