Topic: "Message in Browser"add to db Karaoke
It's over an hour that VDJ8 says the title message. I'm trying for the 1st time to add my karaoke songs to 8 database. Over an hour seems too long?? I have them on an external drive. VDJ7 usually takes a maximum of 15 minutes to do every file I have
geposted Tue 24 Jun 14 @ 7:36 pm
Adding MP3's, video and ITunes no problem... They add to the database in a few seconds to a few minutes, no problem. Just the karaoke seems to be a problem. I'm trying again for the third time
It just finished the karaoke files 1.5 hours? Seems way too long...
Are the karaoke files zipped?
If so, then it will take a lot longer because VirtualDJ has to decompress each ZIP to be able to read information from the files contained within each ZIP file.
Yes they are zipped. Thanks for your reply.
