Forum: Old versions
Topic: Looping songs
I have a question. Whenever i try and loop songs using my controller (hercules air) VDJ always randomly selects what to loop. So like, if i set it to loop 4, and then i press out on my controller, it sometimes does 4, but mostly it'll do 2, or 1, or 1/2. no matter what i try, it does this. same w/ 8 and 16. is there some way i can stop this? i tried the software that actually came w/ my controller (which i donot like at all) and it does not do this. VDJ 7 free and 8 both do this.
geposted Wed 25 Jun 14 @ 1:24 pm
Yeah the in out loop buttons, whomever thought up that's the way it should be done wants shooting
simply you press in at the loop start point and out at the end point and it will sort the length for you
realistically without a recent in point, out should just back loop but it doesn't
HERE'S THE FIX
I don't know much about your controller but if the only way you use the loop function is, set length, loop on, loop off,
you can change the mapping from 'loop_out' to 'loop'
And it works like so, press it now, it will loop now at the length set until you press again.
