Topic: Deleting Favourites
Whenever I try to delete a Favourite folder I have created from the menu on the bottom left hand side of the application VDJ crashes and stops running.
I am running VDJ 8 & OSX 10.7.5
Wondered if anyone else had the same issue?
Steve
geposted Wed 25 Jun 14 @ 6:40 pm
It doesn't happen on Win 1855, you'll need another mac user to try.
Ok. Fair point - I guess I'll just have to wait for a Mac user to have the same issue. Ironically it appears that its not just on Favourites it does this. It crashes each time I attempt to remove a playlist/folder/favourite from the left side list….weird!
How are you deleting it? What's your process?
Are you pressing a key, selecting a menu option, dragging to trash.......?
