Forum: VirtualDJ Skins
Topic: V8 but by FRUiT - Page: 1
FruitPRO InfinityMember since 2003
Hello all :)
New skin, v8 engine compatable, to replace my old denon 1800F.
Main features :
- move-able / hide-able rhythmzone across the decks
- plenty of rhythmzones styles
- VERSATILITY (you may hide almost any part of the skin using menus)
- mirror-able right deck
- loads of custom buttons seemlessly integrated
- more mixer pages (in the future)
- several usefull menus
- ... + a lot more...
Actually I'm optimising the core xml file. It's not simply a V5 engine skin with more buttons. It fully uses class properties to completely avoid duplicate code and so drastically reduce the xml file size (under 4700 lines now). It tries to show you the incredible possibilities of the amazing v8 skin engine, and get the very best from it. Also the accent is clearly on user configuration, meaning YOU design the skin to feet your needs, and only show the buttons/parts you truely use. Once the code is optimized, I'll add several new mixer's pages and amazing new tools.
Also it has a "jukebox" mode with a fullscreen customized browser, where still can look at the wave, drop your songs, hit play or stop.
Hope you will enjoy :)
geposted Thu 26 Jun 14 @ 6:20 am
Where is it..
geposted Thu 26 Jun 14 @ 6:42 am
Pending review :(
geposted Thu 26 Jun 14 @ 7:10 am
geposted Thu 26 Jun 14 @ 5:10 pm
Cool thx daddy :)
geposted Thu 26 Jun 14 @ 5:13 pm
Nice - people like options!!
Good to see you back!!
geposted Thu 26 Jun 14 @ 5:50 pm
Thx :) you, and dad helped me a lot !
geposted Thu 26 Jun 14 @ 6:16 pm
Yes, there are a lot of options in this skin!
I like the option for VU meters on the decks.
In the full screen browser mode, why is there a view options button when the same options are available via the 'dot' on the right of the font size buttons?
geposted Thu 26 Jun 14 @ 6:37 pm
Because I don't like submenus, it's difficult I'm lazy.
I use them only when forced to, I try to never have more than one level of submenus.
geposted Thu 26 Jun 14 @ 6:48 pm
yaetownPRO InfinityMember since 2010
By far the best VDJ 8 default skin. Can't believe how intuitive it is. Good looking Fruit. You outdid yourself.
geposted Fri 27 Jun 14 @ 12:45 am
xgl_djPRO InfinityMember since 2004
I love the customization.. Nice.
geposted Fri 27 Jun 14 @ 12:59 am
Thx gees :)
geposted Fri 27 Jun 14 @ 7:04 am
This is what the default skin SHOULD have been Nice job , very impressive
geposted Fri 27 Jun 14 @ 8:52 am
Thx, by the way who wrote the original default skin ?
geposted Fri 27 Jun 14 @ 9:19 am
fede74PRO InfinityMember since 2006
great job ..... I would say that 'the skin more' practical and functional among all the other .... if you could add the ability 'to skip forward or backward the beats of the song .... and then for convenience ', autosink just clicking on the play button with the right mouse button!
geposted Fri 27 Jun 14 @ 10:05 am
MMMM,
For the play button, it already has the action 'reverse' on the rightclick event. But I can rather put the autosync action when holding the button, or when rightclicking the sync button, please tell me, what would you prefer ?
Also, which action should be triggered ? play_sync or play_sync_onbeat ?
Skip forward or backward, doesn't the 'seek' buttons on the skin do it ? (in the deck's menu). Actually it may skip 4, 16, 32 and 128 beats.
geposted Fri 27 Jun 14 @ 10:33 am
I was not aware of the reverse function in the right mouse button .... nice :-) but I think it's more 'useful' play sync "in that key .... to skip the lines of 4 ... 8 ... . etc ... should create a new key .... so that you can 'do but do not know how!
geposted Fri 27 Jun 14 @ 11:16 am
Fed , why not map the custom buttons on the sides of the decks to do start/sync
geposted Fri 27 Jun 14 @ 11:17 am
I'd love to see the skin, (the preview is useless) just to see the possibilities, because it sounds like you've realised the potential of V8 skins. I'm sat on an idea of having every dial slider and button as a custom so you can rescript more or less everything without venturing into the skin xml, I'm just waiting for the skin wiki
geposted Fri 27 Jun 14 @ 12:10 pm
You can see the skin!! You know what you need to do!! ;-)
geposted Fri 27 Jun 14 @ 12:17 pm
3%
