Hi All,
Having a bit of trouble with the cached songs showing up in VDJ 8. Directory structure looks fine. Files are there. They just not showing up in the interface when I look at the downloaded content. I have a couple of years worth that I would have no clue as to what I have in there if I had to redownload them. Any thoughts?
geposted Thu 26 Jun 14 @ 2:57 pm
If you have moved the cached files to different folders than the default /Cache folder, then they wont appear there.
You will need to create a Filter Folder with filter: file type contains vdjcache and name it e.g. "MyCachedTracks"
geposted Thu 26 Jun 14 @ 5:48 pm
Directory has not been moved. It is still the default location for cache files.
geposted Sat 28 Jun 14 @ 8:45 pm
