Forum: Old versions
Topic: ASIO Sound Driver Error?
Hello, this is my first post on the VirtualDJ Forum, and I have a bit of an annoyance with VirtualDJ, I've tried using the ASIO Sound Driver for a more advance configuration but every time I try to use it, I get this error; "Error in the ASIO sound driver: your sound card is probably not connected or your settings are incorrect". I've tried a lot to fix this problem yet to no avail. I have reset all of the settings to defualt via VirtualDJ, and as soon as I click on ASIO Config, or Apply, I get that error. I'm just a casual DJ'er I don't have turn tables, external sound cards, or anything of the such. I have Virtual Audio Cable, and Realtek HD Audio, the sound card is on the motherboard, I don't actually have a PCI sound card, but here is all of my PC specifications and then some;
Hopefully someone can help me troubleshoot this, thanks!
CPU: AMD FX-6300 Black Edition @3.50Ghz (Stock)
GPU: AMD XFX Core Edition R7850 2GB GDDR5 (Stock)
RAM: Kingston HyperX BLU 8GB (2x4GB) @1600Mhz (Stock)
HDD: Seagate Barracuda 1000GB (1TB) @7200 RPM
HDD 2: Seagate Barracuda 1000GB (1TB) @7200 RPM
MOBO: Gigabyte 990FXA-UD3 Rev. 4.0
PSU: Corsair CX750M 80+ Bronze Certified.
CD Drive: Super Ritemaster
CASE: Rosewill Challenger
MONITOR: ASUS VS208
Recording Software: Fraps
Live Stream Software: OBS
(Accessories)
Keyboard: Logitech G510 Gaming Keyboard
Mouse: Logitech G600 MMO Gaming Mouse
Microphone: Blue Snowball
Speakers: Logitech Speakers
Headset: Turtle Beach PX22 Amplified Gaming Headset
Webcam: Logitech C615 HD Webcam
geposted Fri 27 Jun 14 @ 1:19 pm
I'd like to add that since I don't have a PCI sound card I'm using the USB Sound. My computers motherboard has Dolby Home Theater with support for all the surround configurations all the way up to 7.1 surround.
You can't use ASIO unless you have an audio interface that supports ASIO (which would have its own ASIO driver).
Unless you've bought a specialist computer, the onboard sound will not be ASIO.
