Forum: Old versions
Topic: NS7 Macbook Pro Virtual DJ Pro Audio Issues
Hi I recently upgraded from a PC to a Mac due to my PC crashing while doing a live gig. Currently I am having an issue with audio files in my Virtual DJ. To be honest the music sound like complete crap, the sound is distorted, and the scratching is less than okay.. When I plug the table in using Serato DJ I have no issues at all. But I do love using my VDJ system is there anyway to fix these audio issues? Thank you for your time.
geposted Sat 28 Jun 14 @ 12:17 pm
I'm assuming you're using v7. Many mac users including myself have had this problem since v7 on osx where the sound has an ''underwater sound'' distortion. Also scratching is terrible. If you upgrade to v8 there's no issue with sound. But if you wanna use v7 you need to turn off the motors play the songs then turn them back on. The numark V7 also has this problem not sure about the NS7II tho.
Thank you for the response. I took your advice and V8 worked like a charm.
I'm sorry, but my Mac system has still the distortion on VDJ 7 and 8. Is there anything else i can do?
hi guys i just switch from traktor to vd8 loving interface and future but i connect to my numark 4trak all function is not working like channels up and downs sound is verry bad and i dont have a base treble middle and gain switch dosent working i dont know what im gana do i have gig this week and i just pised off please help me guys to complete mapping my virtual dj 8 to numark 4trak thanks
