Forum: Old versions
Topic: Mapping Question for NS6
Hello.
I have a Question for the Mapper of the Numark NS6.
How can i map the Samplerpads , that These also works with the Remix-Mode?
In the Remix-Mode the Sampler-Pads no working.
I will the pads control with my Numark. All Pads.
And the 2. Question is.
The Pitch Arrows only works , If I move the pitch up or down with the mouse or Keyboard.
How can I map the NS6 , that she works whit the Hardwareslider too?
Sorry for My bad english.
Thanks for all help.
Dani
geposted Sat 28 Jun 14 @ 1:24 pm
If those buttons are mapped as sampler_pad x, where x is a number from 1 to... n, then those buttons will also trigger the Remix points of the selected track.
You will need of course to select the Remix mode from the Sampler or have a button mapped as .. sampler_bank '{Remix mode}' in order that bank to be loaded.
The arrows Leds of the pitch slider are mapped to indicate the direction you need to move your hardware pitch slider, in order to "catch" the software one. So,if you press SYNC and the software pitch slider moves to a different position than your controller's pitch slider, looking at those leds you will know to which direction you need to move the pitch without looking at the screen.
Those can be mapped of course to whatever you wish.
To me it doesnt makes much sense to map them to indicate the hardware slider position.... however if you still need that, then try to map the down arrow as ..
param_bigger 50% ? on : off
and the up arrow as
param_smaller 50% ? on : off
OK, I have a very big thanks to you! :-)
Now, my mapping is so as I would like to have it.
The Mappin for the Arrows is :
param_bigger pitch 50% ? blink
param_smaller pitch 50% ? blink
Now this works also when I adjust the slider..
And as if the pitch in the software not on 0 100%...
In VDJ 7 These have no Funktion.
And for the Sampler Pads I have the Error found to.
There was the Mapping Command Samler_Play_Stutter before Sampler_pad 1.2..3 ect.
That's why the pads had no function.
I have a great Thank for Your help :-)
