Forum: Old versions
Topic: Hercules RMX Issues
baz727PRO InfinityMember since 2013
Help !
Been using a Hercules RMX with Windows 8 & VDJ 7 with no issues for months. Decided it would be a good idea to install the software on a backup laptop with Windows 7. Should not be an issue as the same software handles XP/ Windows 7 / Windows 8.
Download would not install because the laptop would not recognise the RMX.
After numerous uninstall / re-installs spoke to Hercules help line who sent clean install instructions. They said if that does not work you will have to re-install Windows - which seems extreme & difficult as it is pre-installed.
It didn't work !
Tried to install on a PC with Windows 7 & a laptop with XP with no success. Won't work on the original Windows 8 laptop either now...
Bought a powered USB port which made no difference.
I am no techie but I think the issue is to do with recently launched firmware. But unless I can get a machine to see the Controller I cannot download that.
Maybe the Controller is faulty. But it is a big coincidence that it only packed up when trying to install it on another machine !
Considering ordering another RMX Controller but don't want that to have the same issues. Might consider a different Controller....
Anyone had any similar issues or got any ideas?
Loads of advice on the net - think I have tried it all ! Spent 1 1/2 days on this now....
All contributions gratefully received !
Barry
geposted Sun 29 Jun 14 @ 10:25 am
If your backup computer doesnt have any USB 3.0, then maybe worths asking from Hercules to send you the old drivers version (before the latest update).
There is also a chance that another driver in your computer may conflict with the hercules ones. Try to disable (uninstall) the Wifi and the webcamera (if available) and try to install drivers again.
Disable any Antivirus too.
geposted Mon 30 Jun 14 @ 5:24 am
I have tried many times to install my rmx on my new hp envy with windows 8 and the new version of VDJ. I have no luck....after install the icon comes up but with an x through it. I have tried uninstall...restart...updating firmware, but nothing. And when I try to do an update it states is is missing an update file. I have included a log...Anyone can help please guide me... Thanks
Information - Hercules DJ Series
System Time: 16:02:02, Date: 07/12/2014 (format: mm/dd/yyyy)
DJSeries Package: 1.HDJS.2014
--->DJSeries DETECTED, SUPPORT TrayBar Agent.
DJSeries2 Package: 1.HDJS.2014
--->DJSeries2 DETECTED, SUPPORT TrayBar Agent.
Update: Automatic update notification.
Display icon at boot time: ON
Operating System Version: CSD= (Platform=2) Version 6.2 (Build 9200)
Processor Count: 8 (Type: 8664) Mask=0x000000FF
C:\Program Files\Guillemot\HDJTray\HDJSeries2TrayBar.exe
Hercules DJSeries TrayBar Version: 1.0.4.8
User Default Language ID = 0x0409
System Directory: C:\Windows\system32
SysWOW64 Directory: C:\Windows\SysWOW64
DJ Tray InterProc Information:
Firmware Updater (running): -
Tray: Cmd=0x00000000, Status=0x00000000, package="", Exit=0
InstanceCount: 4
HDJAPI Information:
Device 0: Hercules DJ Software API
Product: Hercules DJ Software API, dwFFlags=0x00000004, Deck:0, Channels: Play=0 Rec.=0
Number of instances: 3
API Version: 2.0.26.17
--> DJ Series API trace: disable
--> DJ Series API trace mode: normal
--> DJ Series API trace path: C:\
Number of low-speed dongles connected: 0
Number of hi-speed dongles connected: 0
Serial Number: -
MIXER Interface:
"Speakers / HP (IDT High Definit" (cDest=1, \\?\hdaudio#func_01&ven_111d&dev_76e0&subsys_103c1967&rev_1003#4&2b9d835d&0&0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\lineoutwave)
"Stereo Mix (IDT High Definition" (cDest=1, \\?\hdaudio#func_01&ven_111d&dev_76e0&subsys_103c1967&rev_1003#4&2b9d835d&0&0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\muxedin1wave)
"Internal Microphone Array (IDT " (cDest=1, \\?\hdaudio#func_01&ven_111d&dev_76e0&subsys_103c1967&rev_1003#4&2b9d835d&0&0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\micin4wave)
MIDI Interface:
(OUT) "Microsoft GS Wavetable Synth" ()
WAVE Interface:
(IN) "Internal Microphone Array (IDT " (\\?\hdaudio#func_01&ven_111d&dev_76e0&subsys_103c1967&rev_1003#4&2b9d835d&0&0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\micin4wave)
(IN) "Stereo Mix (IDT High Definition" (\\?\hdaudio#func_01&ven_111d&dev_76e0&subsys_103c1967&rev_1003#4&2b9d835d&0&0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\muxedin1wave)
(OUT) "Speakers / HP (IDT High Definit" (\\?\hdaudio#func_01&ven_111d&dev_76e0&subsys_103c1967&rev_1003#4&2b9d835d&0&0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\lineoutwave)
System Directory Specific Contents:
--A-- 717824 03/05/2014 2.0.26.17 C:\Windows\system32\hdjapi.dll
--A-- 103936 03/05/2014 1.0.9.0 C:\Windows\system32\hrfdongle.dll
--A-- 369664 12/10/2009 3.8.0.0 C:\Windows\system32\hdjasiocpl.dll
--A-- 92672 03/04/2014 4.7.3.0 C:\Windows\system32\hdjasiou.dll
--A-- 78848 03/04/2014 6.1.7600.16385 C:\Windows\system32\HerculesDJDevices.dll
--A-- 79872 03/05/2013 6.1.7600.16385 C:\Windows\system32\HerculesDJUSBAudioDevices_x64.dll
--A-- 249344 03/05/2014 3.1.8.0 C:\Windows\system32\HDJusbaudioapi_x64.dll
--A-- 323376 03/05/2014 5.9.9.0 C:\Windows\system32\drivers\hdjasiok.sys
--A-- 296240 03/05/2014 6.2.6.0 C:\Windows\system32\drivers\hdjbulk.sys
--A-- 276272 03/05/2014 5.2.2.0 C:\Windows\system32\drivers\hdjmidi.sys
--A-- 38704 03/05/2014 4.0.1.0 C:\Windows\system32\drivers\hdjctrl.sys
--A-- 725504 03/05/2014 2.0.26.17 C:\Windows\syswow64\hdjapi.dll
--A-- 73728 12/04/2009 2.0.6.0 C:\Windows\syswow64\hdjsapi.dll
--A-- 88064 03/05/2014 1.0.9.0 C:\Windows\syswow64\hrfdongle.dll
--A-- 278528 12/10/2009 3.8.0.0 C:\Windows\syswow64\hdjasiocpl.dll
--A-- 79360 03/04/2014 4.7.3.0 C:\Windows\syswow64\hdjasiou.dll
***** REGISTRY CONTENT UNDER LOCAL MACHINE *****
Path: SOFTWARE\Hercules Technologies
--->Subkey: \DJConsoleSeries
"DJTrayAgent" <TYPE:DWORD> : 0x00000001
"HDJSeriesCPLPath" <TYPE:SZ> : "C:\Program Files\Hercules\Audio\DJ Console Series\HDJSeriesCPL.exe"
"Package" <TYPE:SZ> : "1.HDJS.2014"
"ASIOBufSize_44100" <TYPE:DWORD> : 0x00000372
"ASIOBufSize_48000" <TYPE:DWORD> : 0x000001E0
--->Subkey: \DJSeries2
"HDJSeries2CPLPath" <TYPE:SZ> : "C:\Program Files\Hercules\Audio\DJ Console Series\cpl2\HDJSeries2CPL.exe"
--->Subkey: \HDJTrayAgent
"HDJTrayAgentPath" <TYPE:SZ> : "C:\Program Files\Guillemot\HDJTray\HDJSeries2TrayBar.exe"
--->Subkey: \RFDongle
"BaseNAD" <TYPE:DWORD> : 0x00049556
***** REGISTRY CONTENT UNDER CURRENT USER *****
"WinPosX" <TYPE:DWORD> : 0x000003C0
"WinPosY" <TYPE:DWORD> : 0x0000021C
"CurCPLSelected" <TYPE:DWORD> : 0x00000000
"PackageUpdate" <TYPE:DWORD> : 0x00000001
"ShowBootTime" <TYPE:DWORD> : 0x00000001
Software Directory Contents: "C:\Program Files\Hercules\Audio\DJ Console Series\"
D---- 0 07/12/2014 .
D---- 0 07/12/2014 ..
D---- 0 07/12/2014 cpl2
D---- 0 07/12/2014 cpl2\.
D---- 0 07/12/2014 cpl2\..
D---- 0 07/12/2014 cpl2\firmware
D---- 0 07/12/2014 cpl2\firmware\.
D---- 0 07/12/2014 cpl2\firmware\..
--A-- 11722 05/01/2012 cpl2\firmware\407.msg
--A-- 11496 05/01/2012 cpl2\firmware\409.msg
--A-- 12516 05/01/2012 cpl2\firmware\40a.msg
--A-- 13504 05/01/2012 cpl2\firmware\40c.msg
--A-- 12598 05/01/2012 cpl2\firmware\410.msg
--A-- 12178 05/01/2012 cpl2\firmware\413.msg
--A-- 3021104 03/04/2014 4.0.9.4 cpl2\firmware\HDJSeries2Updater.exe
--A-- 25728 08/07/2012 cpl2\firmware\RMX2_PIC.djc
--A-- 35712 08/03/2012 cpl2\firmware\RMX2_XMOS.dja
--A-- 3286320 03/04/2014 1.0.1.13 cpl2\HDJSeries2CPL.exe
D---- 0 07/12/2014 cpl2\msgFiles
D---- 0 07/12/2014 cpl2\msgFiles\.
D---- 0 07/12/2014 cpl2\msgFiles\..
--A-- 9594 03/15/2013 cpl2\msgFiles\407.msg
--A-- 8916 10/15/2012 cpl2\msgFiles\409.msg
--A-- 9368 03/15/2013 cpl2\msgFiles\40a.msg
--A-- 9688 03/15/2013 cpl2\msgFiles\40c.msg
--A-- 10026 03/15/2013 cpl2\msgFiles\410.msg
--A-- 9238 03/15/2013 cpl2\msgFiles\413.msg
D---- 0 07/12/2014 cpl2\Skin
D---- 0 07/12/2014 cpl2\Skin\.
D---- 0 07/12/2014 cpl2\Skin\..
D---- 0 07/12/2014 cpl2\Skin\DJ Console RMX2
D---- 0 07/12/2014 cpl2\Skin\DJ Console RMX2\.
D---- 0 07/12/2014 cpl2\Skin\DJ Console RMX2\..
--A-- 4211 03/15/2013 cpl2\Skin\DJ Console RMX2\BtnCheck.ggff
--A-- 3333 03/15/2013 cpl2\Skin\DJ Console RMX2\BtnClose.ggff
--A-- 67389 03/15/2013 cpl2\Skin\DJ Console RMX2\BtnHttpLink.ggff
--A-- 11937 03/15/2013 cpl2\Skin\DJ Console RMX2\BtnLinkVolBooth.ggff
--A-- 11937 03/15/2013 cpl2\Skin\DJ Console RMX2\BtnLinkVolumes.ggff
--A-- 25622 03/15/2013 cpl2\Skin\DJ Console RMX2\BtnMute.ggff
--A-- 5123 03/15/2013 cpl2\Skin\DJ Console RMX2\BtnRadio.ggff
--A-- 20957 03/15/2013 cpl2\Skin\DJ Console RMX2\BtnTabCenter.ggff
--A-- 18732 03/15/2013 cpl2\Skin\DJ Console RMX2\BtnTabLeft.ggff
--A-- 16776 03/15/2013 cpl2\Skin\DJ Console RMX2\BtnTabRight.ggff
--A-- 2717 03/15/2013 cpl2\Skin\DJ Console RMX2\ComboBox.ggff
--A-- 1734 03/15/2013 cpl2\Skin\DJ Console RMX2\ComboBoxList.ggff
--A-- 1096 03/15/2013 cpl2\Skin\DJ Console RMX2\ComboBoxListShorter.ggff
--A-- 1026 03/15/2013 cpl2\Skin\DJ Console RMX2\ComboBoxListShortest.ggff
--A-- 3394 03/15/2013 cpl2\Skin\DJ Console RMX2\ComboBoxSmall.ggff
--A-- 2374 03/15/2013 cpl2\Skin\DJ Console RMX2\ComboBoxSmallest.ggff
--A-- 535 03/15/2013 cpl2\Skin\DJ Console RMX2\ComboBoxSmallestList.ggff
--A-- 1205 03/15/2013 cpl2\Skin\DJ Console RMX2\ComboBoxSmallList.ggff
--A-- 726 03/15/2013 cpl2\Skin\DJ Console RMX2\ComboBoxSmallListShorter.ggff
--A-- 937 03/15/2013 cpl2\Skin\DJ Console RMX2\ComboDown.ggff
--A-- 510 03/15/2013 cpl2\Skin\DJ Console RMX2\ComboScroll.ggff
--A-- 937 03/15/2013 cpl2\Skin\DJ Console RMX2\ComboUp.ggff
--A-- 4159 05/04/2012 cpl2\Skin\DJ Console RMX2\HDJSeriesSkinScript.txt
--A-- 2128100 03/15/2013 cpl2\Skin\DJ Console RMX2\MainDlgBckgrnd.ggff
--A-- 38815 03/15/2013 cpl2\Skin\DJ Console RMX2\MainDlgPos.ggff
--A-- 12518 03/15/2013 cpl2\Skin\DJ Console RMX2\SliderBalance1.ggff
--A-- 12518 03/15/2013 cpl2\Skin\DJ Console RMX2\SliderBalance2.ggff
--A-- 12520 03/15/2013 cpl2\Skin\DJ Console RMX2\SliderBalance3.ggff
--A-- 19278 03/15/2013 cpl2\Skin\DJ Console RMX2\SliderTalkover.ggff
--A-- 19040 03/15/2013 cpl2\Skin\DJ Console RMX2\SliderVol1.ggff
--A-- 19595 03/15/2013 cpl2\Skin\DJ Console RMX2\SliderVol2.ggff
--A-- 20456 03/15/2013 cpl2\Skin\DJ Console RMX2\SliderVol3.ggff
--A-- 20469 03/15/2013 cpl2\Skin\DJ Console RMX2\SliderVol4.ggff
--A-- 20537 03/15/2013 cpl2\Skin\DJ Console RMX2\SliderVol5.ggff
--A-- 20958 03/15/2013 cpl2\Skin\DJ Console RMX2\SliderVol6.ggff
D---- 0 07/12/2014 drivers
D---- 0 07/12/2014 drivers\.
D---- 0 07/12/2014 drivers\..
D---- 0 07/12/2014 drivers\amd64
D---- 0 07/12/2014 drivers\amd64\.
D---- 0 07/12/2014 drivers\amd64\..
--A-- 369664 12/10/2009 3.8.0.0 drivers\amd64\HDJAsioCpl64.dll
--A-- 323376 03/05/2014 5.9.9.0 drivers\amd64\HDJAsioK.sys
--A-- 92672 03/04/2014 4.7.3.0 drivers\amd64\HDJASIOU64.DLL
--A-- 296240 03/05/2014 6.2.6.0 drivers\amd64\HDJBulk.sys
--A-- 157696 03/04/2014 3.8.0.0 drivers\amd64\HDJCProp64.DLL
--A-- 38704 03/05/2014 4.0.1.0 drivers\amd64\HDJCTRL.sys
--A-- 276272 03/05/2014 5.2.2.0 drivers\amd64\HDJMidi.sys
--A-- 50688 03/04/2014 1.0.3.0 drivers\amd64\HerculesDJControlMP3.EXE
--A-- 78848 03/04/2014 6.1.7600.16385 drivers\amd64\HerculesDJDevices.dll
--A-- 1721576 07/14/2009 1.9.7600.16385 drivers\amd64\WdfCoInstaller01009.dll
--A-- 531512 08/26/2008 2.1.1.0 drivers\DIFxAPI.dll
--A-- 345392 03/04/2014 1.0.8.0 drivers\gcorpdinst.exe
--A-- 9343 03/04/2014 drivers\HDJAsioK.inf
--A-- 15837 03/04/2014 drivers\HDJBulk.inf
--A-- 4208 01/07/2014 drivers\HDJCtrl.inf
-RA-- 365 02/04/2013 drivers\HDJcustom.ini
--A-- 23218 02/21/2014 drivers\HDJMidi.inf
--A-- 14412 03/05/2014 drivers\hdjusbaudio.cat
--A-- 9096 03/05/2014 drivers\HDJusbaudio.inf
--A-- 370992 03/05/2014 3.1.8.0 drivers\HDJusbaudio.sys
--A-- 218112 03/05/2014 3.1.8.0 drivers\HDJusbaudioapi.dll
--A-- 249344 03/05/2014 3.1.8.0 drivers\HDJusbaudioapi_x64.dll
--A-- 180224 03/05/2014 3.1.8.0 drivers\HDJusbaudioasio.dll
--A-- 204288 03/05/2014 3.1.8.0 drivers\HDJusbaudioasio_x64.dll
--A-- 11155 03/05/2014 drivers\hdjusbaudioks.cat
--A-- 8129 03/05/2014 drivers\HDJusbaudioks.inf
--A-- 93488 03/05/2014 3.1.8.0 drivers\HDJusbaudioks.sys
--A-- 110896 03/05/2014 3.1.8.0 drivers\HDJusbaudioks_x64.sys
--A-- 455984 03/05/2014 3.1.8.0 drivers\HDJusbaudio_x64.sys
--A-- 25392 03/04/2014 1.0.0.0 drivers\hercInstallHelper.exe
--A-- 22241 03/05/2014 drivers\herculesdj.cat
--A-- 19737 03/05/2014 drivers\herculesdjmp3.cat
--A-- 79872 03/05/2013 6.1.7600.16385 drivers\HerculesDJUSBAudioDevices.dll
--A-- 79872 03/05/2013 6.1.7600.16385 drivers\HerculesDJUSBAudioDevices_x64.dll
D---- 0 07/12/2014 drivers\x86
D---- 0 07/12/2014 drivers\x86\.
D---- 0 07/12/2014 drivers\x86\..
--A-- 278528 12/10/2009 3.8.0.0 drivers\x86\HDJAsioCpl.dll
--A-- 275760 03/05/2014 5.9.9.0 drivers\x86\HDJAsioK.sys
--A-- 79360 03/04/2014 4.7.3.0 drivers\x86\HDJASIOU.DLL
--A-- 252720 03/05/2014 6.2.6.0 drivers\x86\HDJBulk.sys
--A-- 141312 03/04/2014 3.8.0.0 drivers\x86\HDJCProp.DLL
--A-- 36656 03/05/2014 4.0.1.0 drivers\x86\HDJCTRL.sys
--A-- 242992 03/05/2014 5.2.2.0 drivers\x86\HDJMidi.sys
--A-- 41472 03/04/2014 1.0.3.0 drivers\x86\HerculesDJControlMP3.EXE
--A-- 77312 03/04/2014 6.1.7600.16385 drivers\x86\HerculesDJDevices.dll
--A-- 1461992 07/14/2009 1.9.7600.16385 drivers\x86\WdfCoInstaller01009.dll
D---- 0 07/12/2014 firmware
D---- 0 07/12/2014 firmware\.
D---- 0 07/12/2014 firmware\..
--A-- 33042 03/04/2014 firmware\407.msg
--A-- 31004 03/04/2014 firmware\409.msg
--A-- 32618 03/04/2014 firmware\40a.msg
--A-- 33256 03/04/2014 firmware\40c.msg
--A-- 32650 03/04/2014 firmware\410.msg
--A-- 31824 03/04/2014 firmware\413.msg
--A-- 25728 06/07/2011 firmware\4MX_PIC.djc
--A-- 8308 02/04/2014 firmware\4MX_TUSB_F.dja
--A-- 25728 06/07/2011 firmware\4SET_PIC.djc
--A-- 8308 02/27/2014 firmware\4SET_TUSB_F.dja
--A-- 58496 08/19/2013 firmware\AIRplus_LM3S.dja
--A-- 58496 07/16/2013 firmware\Air_LM3S.dja
--A-- 8206 07/03/2007 firmware\DJC_TUSB_F.dja
--A-- 6398256 03/04/2014 4.1.3.0 firmware\HDJSeriesUpdater.exe
--A-- 58496 07/16/2013 firmware\Instinct_LM3S.dja
--A-- 12320 02/06/2007 firmware\MK2_PSOC1.djc
--A-- 12320 02/06/2007 firmware\MK2_PSOC2.djc
--A-- 8207 02/04/2014 firmware\MK2_TUSB_F.dja
--A-- 8308 02/04/2014 firmware\MK4_TUSB_F.dja
--A-- 11552 07/06/2009 firmware\RMX_PSOC.djc
--A-- 8315 03/04/2014 firmware\RMX_TUSB_F.dja
--A-- 11552 07/17/2008 firmware\STEEL_PSOC_USB.djc
--A-- 8212 02/18/2014 firmware\T46_TUSB_F.dja
--A-- 518 01/21/2014 firmware\WAVE_BM57.djb
--A-- 119936 03/05/2014 firmware\WAVE_LM4F.djc
--A-- 3410224 03/04/2014 2.0.12.25 HDJSeriesCPL.exe
D---- 0 07/12/2014 HelpFiles
D---- 0 07/12/2014 HelpFiles\.
D---- 0 07/12/2014 HelpFiles\..
D---- 0 07/12/2014 HelpFiles\DJ Console
D---- 0 07/12/2014 HelpFiles\DJ Console\.
D---- 0 07/12/2014 HelpFiles\DJ Console\..
--A-- 65069 04/02/2007 HelpFiles\DJ Console\dcpl0407.chm
--A-- 63836 04/02/2007 HelpFiles\DJ Console\dcpl0409.chm
--A-- 62420 04/02/2007 HelpFiles\DJ Console\dcpl040a.chm
--A-- 35414 04/02/2007 HelpFiles\DJ Console\dcpl040c.chm
--A-- 62820 04/02/2007 HelpFiles\DJ Console\dcpl0410.chm
--A-- 64755 04/02/2007 HelpFiles\DJ Console\dcpl0413.chm
D---- 0 07/12/2014 msgFiles
D---- 0 07/12/2014 msgFiles\.
D---- 0 07/12/2014 msgFiles\..
--A-- 25392 03/04/2014 msgFiles\407.msg
--A-- 24030 03/04/2014 msgFiles\409.msg
--A-- 25416 03/04/2014 msgFiles\40a.msg
--A-- 25426 03/04/2014 msgFiles\40c.msg
--A-- 25612 03/04/2014 msgFiles\410.msg
--A-- 24912 03/04/2014 msgFiles\413.msg
D---- 0 07/12/2014 Skin
D---- 0 07/12/2014 Skin\.
D---- 0 07/12/2014 Skin\..
D---- 0 07/12/2014 Skin\Deejay Trim 4and6
D---- 0 07/12/2014 Skin\Deejay Trim 4and6\.
D---- 0 07/12/2014 Skin\Deejay Trim 4and6\..
--A-- 52 03/04/2014 Skin\Deejay Trim 4and6\AboutDlgBckgrnd.ggff
--A-- 64 03/04/2014 Skin\Deejay Trim 4and6\AboutDlgPos.ggff
--A-- 52 03/04/2014 Skin\Deejay Trim 4and6\BmpCinema.ggff
--A-- 18265 03/04/2014 Skin\Deejay Trim 4and6\Btn2in6out.ggff
--A-- 17695 03/04/2014 Skin\Deejay Trim 4and6\Btn4in4out.ggff
--A-- 64 03/04/2014 Skin\Deejay Trim 4and6\BtnAboutBox.ggff
--A-- 61 03/04/2014 Skin\Deejay Trim 4and6\BtnAboutOk.ggff
--A-- 14937 03/04/2014 Skin\Deejay Trim 4and6\BtnAsio.ggff
--A-- 81 03/04/2014 Skin\Deejay Trim 4and6\BtnBatteryState.ggff
--A-- 67 03/04/2014 Skin\Deejay Trim 4and6\BtnBlueTooth.ggff
--A-- 3766 03/04/2014 Skin\Deejay Trim 4and6\BtnCheck.ggff
--A-- 2254 03/04/2014 Skin\Deejay Trim 4and6\BtnClose.ggff
--A-- 94 03/04/2014 Skin\Deejay Trim 4and6\BtnCrossFaderFigure.ggff
--A-- 66 03/04/2014 Skin\Deejay Trim 4and6\BtnHeadphone.ggff
--A-- 81 03/04/2014 Skin\Deejay Trim 4and6\BtnHeadphoneSwitch.ggff
--A-- 64 03/04/2014 Skin\Deejay Trim 4and6\BtnHelp.ggff
--A-- 64 03/04/2014 Skin\Deejay Trim 4and6\BtnHideAsioBckgrnd.ggff
--A-- 64614 03/04/2014 Skin\Deejay Trim 4and6\BtnHttpLink.ggff
--A-- 64 03/04/2014 Skin\Deejay Trim 4and6\BtnHwState.ggff
--A-- 19432 03/04/2014 Skin\Deejay Trim 4and6\BtnLineIn.ggff
--A-- 15979 03/04/2014 Skin\Deejay Trim 4and6\BtnLineIn2.ggff
--A-- 5466 03/04/2014 Skin\Deejay Trim 4and6\BtnLinkVolumes.ggff
--A-- 74 03/04/2014 Skin\Deejay Trim 4and6\BtnMasterMute.ggff
--A-- 11245 03/04/2014 Skin\Deejay Trim 4and6\BtnMic.ggff
--A-- 3871 03/04/2014 Skin\Deejay Trim 4and6\BtnMute.ggff
--A-- 67 03/04/2014 Skin\Deejay Trim 4and6\BtnOnAir.ggff
--A-- 13478 03/04/2014 Skin\Deejay Trim 4and6\BtnOut12.ggff
--A-- 13547 03/04/2014 Skin\Deejay Trim 4and6\BtnOut34.ggff
--A-- 71 03/04/2014 Skin\Deejay Trim 4and6\BtnOutputConfig.ggff
--A-- 67 03/04/2014 Skin\Deejay Trim 4and6\BtnPadlock.ggff
--A-- 66 03/04/2014 Skin\Deejay Trim 4and6\BtnRadio.ggff
--A-- 67 03/04/2014 Skin\Deejay Trim 4and6\BtnSpkBackLeft.ggff
--A-- 68 03/04/2014 Skin\Deejay Trim 4and6\BtnSpkBackRight.ggff
--A-- 67 03/04/2014 Skin\Deejay Trim 4and6\BtnSpkFrontCenter.ggff
--A-- 67 03/04/2014 Skin\Deejay Trim 4and6\BtnSpkFrontLeft.ggff
--A-- 67 03/04/2014 Skin\Deejay Trim 4and6\BtnSpkFrontRight.ggff
--A-- 64 03/04/2014 Skin\Deejay Trim 4and6\BtnSpkIdBackLeft.ggff
--A-- 64 03/04/2014 Skin\Deejay Trim 4and6\BtnSpkIdBackRight.ggff
--A-- 64 03/04/2014 Skin\Deejay Trim 4and6\BtnSpkIdFrontCenter.ggff
--A-- 64 03/04/2014 Skin\Deejay Trim 4and6\BtnSpkIdFrontLeft.ggff
--A-- 64 03/04/2014 Skin\Deejay Trim 4and6\BtnSpkIdFrontRight.ggff
--A-- 64 03/04/2014 Skin\Deejay Trim 4and6\BtnSpkIdSubW.ggff
--A-- 67 03/04/2014 Skin\Deejay Trim 4and6\BtnSpkSubW.ggff
--A-- 5535 03/04/2014 Skin\Deejay Trim 4and6\BtnTabCenter.ggff
--A-- 5007 03/04/2014 Skin\Deejay Trim 4and6\BtnTabCenter2.ggff
--A-- 6798 03/04/2014 Skin\Deejay Trim 4and6\BtnTabLeft.ggff
--A-- 5923 03/04/2014 Skin\Deejay Trim 4and6\BtnTabRight.ggff
--A-- 67 03/04/2014 Skin\Deejay Trim 4and6\BtnTestLeds.ggff
--A-- 27220 03/04/2014 Skin\Deejay Trim 4and6\BtnUSBHub.ggff
--A-- 15949 03/04/2014 Skin\Deejay Trim 4and6\BtnWDM.ggff
--A-- 6311 03/04/2014 Skin\Deejay Trim 4and6\ComboBox.ggff
--A-- 6926 03/04/2014 Skin\Deejay Trim 4and6\ComboBoxList.ggff
--A-- 4950 03/04/2014 Skin\Deejay Trim 4and6\ComboBoxListShorter.ggff
--A-- 4469 03/04/2014 Skin\Deejay Trim 4and6\ComboBoxListShortest.ggff
--A-- 5933 03/04/2014 Skin\Deejay Trim 4and6\ComboBoxSmall.ggff
--A-- 61 03/04/2014 Skin\Deejay Trim 4and6\ComboBoxSmallest.ggff
--A-- 52 03/04/2014 Skin\Deejay Trim 4and6\ComboBoxSmallestList.ggff
--A-- 8294 03/04/2014 Skin\Deejay Trim 4and6\ComboBoxSmallList.ggff
--A-- 3467 03/04/2014 Skin\Deejay Trim 4and6\ComboBoxSmallListShorter.ggff
--A-- 1225 03/04/2014 Skin\Deejay Trim 4and6\ComboDown.ggff
--A-- 1042 03/04/2014 Skin\Deejay Trim 4and6\ComboScroll.ggff
--A-- 1225 03/04/2014 Skin\Deejay Trim 4and6\ComboUp.ggff
--A-- 3514 12/16/2010 Skin\Deejay Trim 4and6\HDJSeriesSkinScript.txt
--A-- 389491 03/04/2014 Skin\Deejay Trim 4and6\MainDlgBckgrnd.ggff
--A-- 45103 03/04/2014 Skin\Deejay Trim 4and6\MainDlgPos.ggff
--A-- 63 03/04/2014 Skin\Deejay Trim 4and6\SliderBalance.ggff
--A-- 7511 03/04/2014 Skin\Deejay Trim 4and6\SliderRmxBalance1.ggff
--A-- 7511 03/04/2014 Skin\Deejay Trim 4and6\SliderRmxBalance2.ggff
--A-- 12839 03/04/2014 Skin\Deejay Trim 4and6\SliderRmxVol1.ggff
--A-- 12839 03/04/2014 Skin\Deejay Trim 4and6\SliderRmxVol2.ggff
--A-- 12839 03/04/2014 Skin\Deejay Trim 4and6\SliderRmxVol3.ggff
--A-- 12839 03/04/2014 Skin\Deejay Trim 4and6\SliderRmxVol4.ggff
--A-- 64 03/04/2014 Skin\Deejay Trim 4and6\SliderSwitch.ggff
--A-- 7511 03/04/2014 Skin\Deejay Trim 4and6\SliderT46Balance3.ggff
--A-- 12839 03/04/2014 Skin\Deejay Trim 4and6\SliderT46Vol5.ggff
--A-- 12839 03/04/2014 Skin\Deejay Trim 4and6\SliderT46Vol6.ggff
--A-- 5013 03/04/2014 Skin\Deejay Trim 4and6\SliderTalkover.ggff
--A-- 63 03/04/2014 Skin\Deejay Trim 4and6\SliderVolume.ggff
--A-- 64 03/04/2014 Skin\Deejay Trim 4and6\SliderVolumeLarge.ggff
--A-- 63 03/04/2014 Skin\Deejay Trim 4and6\SliderVolumeSmall.ggff
D---- 0 07/12/2014 Skin\DJ 4Set
D---- 0 07/12/2014 Skin\DJ 4Set\.
D---- 0 07/12/2014 Skin\DJ 4Set\..
--A-- 52 03/04/2014 Skin\DJ 4Set\AboutDlgBckgrnd.ggff
--A-- 64 03/04/2014 Skin\DJ 4Set\AboutDlgPos.ggff
--A-- 52 03/04/2014 Skin\DJ 4Set\BmpCinema.ggff
--A-- 67 03/04/2014 Skin\DJ 4Set\Btn2in6out.ggff
--A-- 67 03/04/2014 Skin\DJ 4Set\Btn4in4out.ggff
--A-- 64 03/04/2014 Skin\DJ 4Set\BtnAboutBox.ggff
--A-- 61 03/04/2014 Skin\DJ 4Set\BtnAboutOk.ggff
--A-- 14616 03/04/2014 Skin\DJ 4Set\BtnAsio.ggff
--A-- 81 03/04/2014 Skin\DJ 4Set\BtnBatteryState.ggff
--A-- 67 03/04/2014 Skin\DJ 4Set\BtnBlueTooth.ggff
--A-- 3615 03/04/2014 Skin\DJ 4Set\BtnCheck.ggff
--A-- 2254 03/04/2014 Skin\DJ 4Set\BtnClose.ggff
--A-- 94 03/04/2014 Skin\DJ 4Set\BtnCrossFaderFigure.ggff
--A-- 66 03/04/2014 Skin\DJ 4Set\BtnHeadphone.ggff
--A-- 81 03/04/2014 Skin\DJ 4Set\BtnHeadphoneSwitch.ggff
--A-- 64 03/04/2014 Skin\DJ 4Set\BtnHelp.ggff
--A-- 64 03/04/2014 Skin\DJ 4Set\BtnHideAsioBckgrnd.ggff
--A-- 42011 03/04/2014 Skin\DJ 4Set\BtnHttpLink.ggff
--A-- 64 03/04/2014 Skin\DJ 4Set\BtnHwState.ggff
--A-- 67 03/04/2014 Skin\DJ 4Set\BtnLineIn.ggff
--A-- 60 03/04/2014 Skin\DJ 4Set\BtnLineIn2.ggff
--A-- 5608 03/04/2014 Skin\DJ 4Set\BtnLinkVolumes.ggff
--A-- 74 03/04/2014 Skin\DJ 4Set\BtnMasterMute.ggff
--A-- 67 03/04/2014 Skin\DJ 4Set\BtnMic.ggff
--A-- 3981 03/04/2014 Skin\DJ 4Set\BtnMute.ggff
--A-- 67 03/04/2014 Skin\DJ 4Set\BtnOnAir.ggff
--A-- 61 03/04/2014 Skin\DJ 4Set\BtnOut12.ggff
--A-- 61 03/04/2014 Skin\DJ 4Set\BtnOut34.ggff
--A-- 71 03/04/2014 Skin\DJ 4Set\BtnOutputConfig.ggff
--A-- 67 03/04/2014 Skin\DJ 4Set\BtnPadlock.ggff
--A-- 6040 03/04/2014 Skin\DJ 4Set\BtnRadio.ggff
--A-- 67 03/04/2014 Skin\DJ 4Set\BtnSpkBackLeft.ggff
--A-- 68 03/04/2014 Skin\DJ 4Set\BtnSpkBackRight.ggff
--A-- 67 03/04/2014 Skin\DJ 4Set\BtnSpkFrontCenter.ggff
--A-- 67 03/04/2014 Skin\DJ 4Set\BtnSpkFrontLeft.ggff
--A-- 67 03/04/2014 Skin\DJ 4Set\BtnSpkFrontRight.ggff
--A-- 64 03/04/2014 Skin\DJ 4Set\BtnSpkIdBackLeft.ggff
--A-- 64 03/04/2014 Skin\DJ 4Set\BtnSpkIdBackRight.ggff
--A-- 64 03/04/2014 Skin\DJ 4Set\BtnSpkIdFrontCenter.ggff
--A-- 64 03/04/2014 Skin\DJ 4Set\BtnSpkIdFrontLeft.ggff
--A-- 64 03/04/2014 Skin\DJ 4Set\BtnSpkIdFrontRight.ggff
--A-- 64 03/04/2014 Skin\DJ 4Set\BtnSpkIdSubW.ggff
--A-- 67 03/04/2014 Skin\DJ 4Set\BtnSpkSubW.ggff
--A-- 18615 03/04/2014 Skin\DJ 4Set\BtnTabCenter.ggff
--A-- 15639 03/04/2014 Skin\DJ 4Set\BtnTabCenter2.ggff
--A-- 13725 03/04/2014 Skin\DJ 4Set\BtnTabLeft.ggff
--A-- 15932 03/04/2014 Skin\DJ 4Set\BtnTabRight.ggff
--A-- 67 03/04/2014 Skin\DJ 4Set\BtnTestLeds.ggff
--A-- 61 03/04/2014 Skin\DJ 4Set\BtnUsbHub.ggff
--A-- 14483 03/04/2014 Skin\DJ 4Set\BtnWDM.ggff
--A-- 6606 03/04/2014 Skin\DJ 4Set\ComboBox.ggff
--A-- 6926 03/04/2014 Skin\DJ 4Set\ComboBoxList.ggff
--A-- 4950 03/04/2014 Skin\DJ 4Set\ComboBoxListShorter.ggff
--A-- 4469 03/04/2014 Skin\DJ 4Set\ComboBoxListShortest.ggff
--A-- 8563 03/04/2014 Skin\DJ 4Set\ComboBoxSmall.ggff
--A-- 5426 03/04/2014 Skin\DJ 4Set\ComboBoxSmallest.ggff
--A-- 4135 03/04/2014 Skin\DJ 4Set\ComboBoxSmallestList.ggff
--A-- 9360 03/04/2014 Skin\DJ 4Set\ComboBoxSmallList.ggff
--A-- 5329 03/04/2014 Skin\DJ 4Set\ComboBoxSmallListShorter.ggff
--A-- 1340 03/04/2014 Skin\DJ 4Set\ComboDown.ggff
--A-- 761 03/04/2014 Skin\DJ 4Set\ComboScroll.ggff
--A-- 1343 03/04/2014 Skin\DJ 4Set\ComboUp.ggff
--A-- 3606 01/25/2011 Skin\DJ 4Set\HDJSeriesSkinScript.txt
--A-- 368306 03/04/2014 Skin\DJ 4Set\MainDlgBckgrnd.ggff
--A-- 47612 03/04/2014 Skin\DJ 4Set\MainDlgPos.ggff
--A-- 63 03/04/2014 Skin\DJ 4Set\SliderBalance.ggff
--A-- 10154 03/04/2014 Skin\DJ 4Set\SliderRmxBalance1.ggff
--A-- 10154 03/04/2014 Skin\DJ 4Set\SliderRmxBalance2.ggff
--A-- 6831 03/04/2014 Skin\DJ 4Set\SliderRmxVol1.ggff
--A-- 6817 03/04/2014 Skin\DJ 4Set\SliderRmxVol2.ggff
--A-- 6817 03/04/2014 Skin\DJ 4Set\SliderRmxVol3.ggff
--A-- 6817 03/04/2014 Skin\DJ 4Set\SliderRmxVol4.ggff
--A-- 64 03/04/2014 Skin\DJ 4Set\SliderSwitch.ggff
--A-- 61 03/04/2014 Skin\DJ 4Set\SliderT46Balance3.ggff
--A-- 61 03/04/2014 Skin\DJ 4Set\SliderT46Vol5.ggff
--A-- 61 03/04/2014 Skin\DJ 4Set\SliderT46Vol6.ggff
--A-- 2426 03/04/2014 Skin\DJ 4Set\SliderTalkover.ggff
--A-- 63 03/04/2014 Skin\DJ 4Set\SliderVolume.ggff
--A-- 64 03/04/2014 Skin\DJ 4Set\SliderVolumeLarge.ggff
--A-- 63 03/04/2014 Skin\DJ 4Set\SliderVolumeSmall.ggff
D---- 0 07/12/2014 Skin\DJ Console
D---- 0 07/12/2014 Skin\DJ Console\.
D---- 0 07/12/2014 Skin\DJ Console\..
--A-- 51311 03/04/2014 Skin\DJ Console\AboutDlgBckgrnd.ggff
--A-- 2725 03/04/2014 Skin\DJ Console\AboutDlgPos.ggff
--A-- 6844 03/04/2014 Skin\DJ Console\BmpCinema.ggff
--A-- 67 03/04/2014 Skin\DJ Console\Btn2in6out.ggff
--A-- 67 03/04/2014 Skin\DJ Console\Btn4in4out.ggff
--A-- 40165 03/04/2014 Skin\DJ Console\BtnAboutBox.ggff
--A-- 3226 03/04/2014 Skin\DJ Console\BtnAboutOk.ggff
--A-- 67 03/04/2014 Skin\DJ Console\BtnAsio.ggff
--A-- 81 03/04/2014 Skin\DJ Console\BtnBatteryState.ggff
--A-- 67 03/04/2014 Skin\DJ Console\BtnBlueTooth.ggff
--A-- 3504 03/04/2014 Skin\DJ Console\BtnCheck.ggff
--A-- 3071 03/04/2014 Skin\DJ Console\BtnClose.ggff
--A-- 94 03/04/2014 Skin\DJ Console\BtnCrossFaderFigure.ggff
--A-- 27715 03/04/2014 Skin\DJ Console\BtnHeadphone.ggff
--A-- 81 03/04/2014 Skin\DJ Console\BtnHeadphoneSwitch.ggff
--A-- 3965 03/04/2014 Skin\DJ Console\BtnHelp.ggff
--A-- 64 03/04/2014 Skin\DJ Console\BtnHideAsioBckgrnd.ggff
--A-- 19747 03/04/2014 Skin\DJ Console\BtnHttpLink.ggff
--A-- 3765 03/04/2014 Skin\DJ Console\BtnHwState.ggff
--A-- 71 03/04/2014 Skin\DJ Console\BtnLineIn.ggff
--A-- 64 03/04/2014 Skin\DJ Console\BtnLineIn2.ggff
--A-- 67 03/04/2014 Skin\DJ Console\BtnLinkVolumes.ggff
--A-- 9227 03/04/2014 Skin\DJ Console\BtnMasterMute.ggff
--A-- 67 03/04/2014 Skin\DJ Console\BtnMic.ggff
--A-- 5883 03/04/2014 Skin\DJ Console\BtnMute.ggff
--A-- 29780 03/04/2014 Skin\DJ Console\BtnOnAir.ggff
--A-- 61 03/04/2014 Skin\DJ Console\BtnOut12.ggff
--A-- 61 03/04/2014 Skin\DJ Console\BtnOut34.ggff
--A-- 71 03/04/2014 Skin\DJ Console\BtnOutputConfig.ggff
--A-- 67 03/04/2014 Skin\DJ Console\BtnPadlock.ggff
--A-- 67 03/04/2014 Skin\DJ Console\BtnRadio.ggff
--A-- 9267 03/04/2014 Skin\DJ Console\BtnSpkBackLeft.ggff
--A-- 9225 03/04/2014 Skin\DJ Console\BtnSpkBackRight.ggff
--A-- 5817 03/04/2014 Skin\DJ Console\BtnSpkFrontCenter.ggff
--A-- 9800 03/04/2014 Skin\DJ Console\BtnSpkFrontLeft.ggff
--A-- 9898 03/04/2014 Skin\DJ Console\BtnSpkFrontRight.ggff
--A-- 1916 03/04/2014 Skin\DJ Console\BtnSpkIdBackLeft.ggff
--A-- 1795 03/04/2014 Skin\DJ Console\BtnSpkIdBackRight.ggff
--A-- 2046 03/04/2014 Skin\DJ Console\BtnSpkIdFrontCenter.ggff
--A-- 1870 03/04/2014 Skin\DJ Console\BtnSpkIdFrontLeft.ggff
--A-- 1783 03/04/2014 Skin\DJ Console\BtnSpkIdFrontRight.ggff
--A-- 1813 03/04/2014 Skin\DJ Console\BtnSpkIdSubW.ggff
--A-- 4741 03/04/2014 Skin\DJ Console\BtnSpkSubW.ggff
--A-- 67 03/04/2014 Skin\DJ Console\BtnTabCenter.ggff
--A-- 67 03/04/2014 Skin\DJ Console\BtnTabCenter2.ggff
--A-- 67 03/04/2014 Skin\DJ Console\BtnTabLeft.ggff
--A-- 67 03/04/2014 Skin\DJ Console\BtnTabRight.ggff
--A-- 67 03/04/2014 Skin\DJ Console\BtnTestLeds.ggff
--A-- 61 03/04/2014 Skin\DJ Console\BtnUsbHub.ggff
--A-- 67 03/04/2014 Skin\DJ Console\BtnWDM.ggff
--A-- 3906 03/04/2014 Skin\DJ Console\ComboBox.ggff
--A-- 1240 03/04/2014 Skin\DJ Console\ComboBoxList.ggff
--A-- 777 03/04/2014 Skin\DJ Console\ComboBoxListShorter.ggff
--A-- 52 03/04/2014 Skin\DJ Console\ComboBoxListShortest.ggff
--A-- 64 03/04/2014 Skin\DJ Console\ComboBoxSmall.ggff
--A-- 61 03/04/2014 Skin\DJ Console\ComboBoxSmallest.ggff
--A-- 52 03/04/2014 Skin\DJ Console\ComboBoxSmallestList.ggff
--A-- 52 03/04/2014 Skin\DJ Console\ComboBoxSmallList.ggff
--A-- 52 03/04/2014 Skin\DJ Console\ComboBoxSmallListShorter.ggff
--A-- 216 03/04/2014 Skin\DJ Console\ComboDown.ggff
--A-- 298 03/04/2014 Skin\DJ Console\ComboScroll.ggff
--A-- 197 03/04/2014 Skin\DJ Console\ComboUp.ggff
--A-- 2543 12/16/2010 Skin\DJ Console\HDJSeriesSkinScript.txt
--A-- 170193 03/04/2014 Skin\DJ Console\MainDlgBckgrnd.ggff
--A-- 16725 03/04/2014 Skin\DJ Console\MainDlgPos.ggff
--A-- 2044 03/04/2014 Skin\DJ Console\SliderBalance.ggff
--A-- 63 03/04/2014 Skin\DJ Console\SliderRmxBalance1.ggff
--A-- 63 03/04/2014 Skin\DJ Console\SliderRmxBalance2.ggff
--A-- 63 03/04/2014 Skin\DJ Console\SliderRmxVol1.ggff
--A-- 63 03/04/2014 Skin\DJ Console\SliderRmxVol2.ggff
--A-- 63 03/04/2014 Skin\DJ Console\SliderRmxVol3.ggff
--A-- 63 03/04/2014 Skin\DJ Console\SliderRmxVol4.ggff
--A-- 1523 03/04/2014 Skin\DJ Console\SliderSwitch.ggff
--A-- 61 03/04/2014 Skin\DJ Console\SliderT46Balance3.ggff
--A-- 61 03/04/2014 Skin\DJ Console\SliderT46Vol5.ggff
--A-- 61 03/04/2014 Skin\DJ Console\SliderT46Vol6.ggff
--A-- 8358 03/04/2014 Skin\DJ Console\SliderTalkover.ggff
--A-- 22178 03/04/2014 Skin\DJ Console\SliderVolume.ggff
--A-- 28497 03/04/2014 Skin\DJ Console\SliderVolumeLarge.ggff
--A-- 8358 03/04/2014 Skin\DJ Console\SliderVolumeSmall.ggff
D---- 0 07/12/2014 Skin\DJ Console 4Mx
D---- 0 07/12/2014 Skin\DJ Console 4Mx\.
D---- 0 07/12/2014 Skin\DJ Console 4Mx\..
--A-- 52 03/04/2014 Skin\DJ Console 4Mx\AboutDlgBckgrnd.ggff
--A-- 64 03/04/2014 Skin\DJ Console 4Mx\AboutDlgPos.ggff
--A-- 52 03/04/2014 Skin\DJ Console 4Mx\BmpCinema.ggff
--A-- 67 03/04/2014 Skin\DJ Console 4Mx\Btn2in6out.ggff
--A-- 67 03/04/2014 Skin\DJ Console 4Mx\Btn4in4out.ggff
--A-- 64 03/04/2014 Skin\DJ Console 4Mx\BtnAboutBox.ggff
--A-- 61 03/04/2014 Skin\DJ Console 4Mx\BtnAboutOk.ggff
--A-- 14836 03/04/2014 Skin\DJ Console 4Mx\BtnAsio.ggff
--A-- 81 03/04/2014 Skin\DJ Console 4Mx\BtnBatteryState.ggff
--A-- 67 03/04/2014 Skin\DJ Console 4Mx\BtnBlueTooth.ggff
--A-- 3844 03/04/2014 Skin\DJ Console 4Mx\BtnCheck.ggff
--A-- 2254 03/04/2014 Skin\DJ Console 4Mx\BtnClose.ggff
--A-- 94 03/04/2014 Skin\DJ Console 4Mx\BtnCrossFaderFigure.ggff
--A-- 66 03/04/2014 Skin\DJ Console 4Mx\BtnHeadphone.ggff
--A-- 81 03/04/2014 Skin\DJ Console 4Mx\BtnHeadphoneSwitch.ggff
--A-- 64 03/04/2014 Skin\DJ Console 4Mx\BtnHelp.ggff
--A-- 64 03/04/2014 Skin\DJ Console 4Mx\BtnHideAsioBckgrnd.ggff
--A-- 41739 03/04/2014 Skin\DJ Console 4Mx\BtnHttpLink.ggff
--A-- 64 03/04/2014 Skin\DJ Console 4Mx\BtnHwState.ggff
--A-- 67 03/04/2014 Skin\DJ Console 4Mx\BtnLineIn.ggff
--A-- 60 03/04/2014 Skin\DJ Console 4Mx\BtnLineIn2.ggff
--A-- 5948 03/04/2014 Skin\DJ Console 4Mx\BtnLinkVolumes.ggff
--A-- 74 03/04/2014 Skin\DJ Console 4Mx\BtnMasterMute.ggff
--A-- 67 03/04/2014 Skin\DJ Console 4Mx\BtnMic.ggff
--A-- 4237 03/04/2014 Skin\DJ Console 4Mx\BtnMute.ggff
--A-- 67 03/04/2014 Skin\DJ Console 4Mx\BtnOnAir.ggff
--A-- 61 03/04/2014 Skin\DJ Console 4Mx\BtnOut12.ggff
--A-- 61 03/04/2014 Skin\DJ Console 4Mx\BtnOut34.ggff
--A-- 71 03/04/2014 Skin\DJ Console 4Mx\BtnOutputConfig.ggff
--A-- 67 03/04/2014 Skin\DJ Console 4Mx\BtnPadlock.ggff
--A-- 5961 03/04/2014 Skin\DJ Console 4Mx\BtnRadio.ggff
--A-- 67 03/04/2014 Skin\DJ Console 4Mx\BtnSpkBackLeft.ggff
--A-- 68 03/04/2014 Skin\DJ Console 4Mx\BtnSpkBackRight.ggff
--A-- 67 03/04/2014 Skin\DJ Console 4Mx\BtnSpkFrontCenter.ggff
--A-- 67 03/04/2014 Skin\DJ Console 4Mx\BtnSpkFrontLeft.ggff
--A-- 67 03/04/2014 Skin\DJ Console 4Mx\BtnSpkFrontRight.ggff
--A-- 64 03/04/2014 Skin\DJ Console 4Mx\BtnSpkIdBackLeft.ggff
--A-- 64 03/04/2014 Skin\DJ Console 4Mx\BtnSpkIdBackRight.ggff
--A-- 64 03/04/2014 Skin\DJ Console 4Mx\BtnSpkIdFrontCenter.ggff
--A-- 64 03/04/2014 Skin\DJ Console 4Mx\BtnSpkIdFrontLeft.ggff
--A-- 64 03/04/2014 Skin\DJ Console 4Mx\BtnSpkIdFrontRight.ggff
--A-- 64 03/04/2014 Skin\DJ Console 4Mx\BtnSpkIdSubW.ggff
--A-- 67 03/04/2014 Skin\DJ Console 4Mx\BtnSpkSubW.ggff
--A-- 18838 03/04/2014 Skin\DJ Console 4Mx\BtnTabCenter.ggff
--A-- 15038 03/04/2014 Skin\DJ Console 4Mx\BtnTabCenter2.ggff
--A-- 13267 03/04/2014 Skin\DJ Console 4Mx\BtnTabLeft.ggff
--A-- 16858 03/04/2014 Skin\DJ Console 4Mx\BtnTabRight.ggff
--A-- 67 03/04/2014 Skin\DJ Console 4Mx\BtnTestLeds.ggff
--A-- 61 03/04/2014 Skin\DJ Console 4Mx\BtnUsbHub.ggff
--A-- 16000 03/04/2014 Skin\DJ Console 4Mx\BtnWDM.ggff
--A-- 6606 03/04/2014 Skin\DJ Console 4Mx\ComboBox.ggff
--A-- 6926 03/04/2014 Skin\DJ Console 4Mx\ComboBoxList.ggff
--A-- 4950 03/04/2014 Skin\DJ Console 4Mx\ComboBoxListShorter.ggff
--A-- 4469 03/04/2014 Skin\DJ Console 4Mx\ComboBoxListShortest.ggff
--A-- 8563 03/04/2014 Skin\DJ Console 4Mx\ComboBoxSmall.ggff
--A-- 5426 03/04/2014 Skin\DJ Console 4Mx\ComboBoxSmallest.ggff
--A-- 4135 03/04/2014 Skin\DJ Console 4Mx\ComboBoxSmallestList.ggff
--A-- 9360 03/04/2014 Skin\DJ Console 4Mx\ComboBoxSmallList.ggff
--A-- 5329 03/04/2014 Skin\DJ Console 4Mx\ComboBoxSmallListShorter.ggff
--A-- 1340 03/04/2014 Skin\DJ Console 4Mx\ComboDown.ggff
--A-- 761 03/04/2014 Skin\DJ Console 4Mx\ComboScroll.ggff
--A-- 1343 03/04/2014 Skin\DJ Console 4Mx\ComboUp.ggff
--A-- 3630 12/16/2010 Skin\DJ Console 4Mx\HDJSeriesSkinScript.txt
--A-- 651994 03/04/2014 Skin\DJ Console 4Mx\MainDlgBckgrnd.ggff
--A-- 47957 03/04/2014 Skin\DJ Console 4Mx\MainDlgPos.ggff
--A-- 63 03/04/2014 Skin\DJ Console 4Mx\SliderBalance.ggff
--A-- 12705 03/04/2014 Skin\DJ Console 4Mx\SliderRmxBalance1.ggff
--A-- 12705 03/04/2014 Skin\DJ Console 4Mx\SliderRmxBalance2.ggff
--A-- 9353 03/04/2014 Skin\DJ Console 4Mx\SliderRmxVol1.ggff
--A-- 9353 03/04/2014 Skin\DJ Console 4Mx\SliderRmxVol2.ggff
--A-- 9353 03/04/2014 Skin\DJ Console 4Mx\SliderRmxVol3.ggff
--A-- 9353 03/04/2014 Skin\DJ Console 4Mx\SliderRmxVol4.ggff
--A-- 64 03/04/2014 Skin\DJ Console 4Mx\SliderSwitch.ggff
--A-- 61 03/04/2014 Skin\DJ Console 4Mx\SliderT46Balance3.ggff
--A-- 61 03/04/2014 Skin\DJ Console 4Mx\SliderT46Vol5.ggff
--A-- 61 03/04/2014 Skin\DJ Console 4Mx\SliderT46Vol6.ggff
--A-- 3852 03/04/2014 Skin\DJ Console 4Mx\SliderTalkover.ggff
--A-- 63 03/04/2014 Skin\DJ Console 4Mx\SliderVolume.ggff
--A-- 64 03/04/2014 Skin\DJ Console 4Mx\SliderVolumeLarge.ggff
--A-- 63 03/04/2014 Skin\DJ Console 4Mx\SliderVolumeSmall.ggff
D---- 0 07/12/2014 Skin\DJ Console Mk2
D---- 0 07/12/2014 Skin\DJ Console Mk2\.
D---- 0 07/12/2014 Skin\DJ Console Mk2\..
--A-- 52 03/04/2014 Skin\DJ Console Mk2\AboutDlgBckgrnd.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk2\AboutDlgPos.ggff
--A-- 52 03/04/2014 Skin\DJ Console Mk2\BmpCinema.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk2\Btn2in6out.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk2\Btn4in4out.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk2\BtnAboutBox.ggff
--A-- 61 03/04/2014 Skin\DJ Console Mk2\BtnAboutOk.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk2\BtnAsio.ggff
--A-- 81 03/04/2014 Skin\DJ Console Mk2\BtnBatteryState.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk2\BtnBlueTooth.ggff
--A-- 10017 03/04/2014 Skin\DJ Console Mk2\BtnCheck.ggff
--A-- 4423 03/04/2014 Skin\DJ Console Mk2\BtnClose.ggff
--A-- 536573 03/04/2014 Skin\DJ Console Mk2\BtnCrossFaderFigure.ggff
--A-- 66 03/04/2014 Skin\DJ Console Mk2\BtnHeadphone.ggff
--A-- 37689 03/04/2014 Skin\DJ Console Mk2\BtnHeadphoneSwitch.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk2\BtnHelp.ggff
--A-- 61738 03/04/2014 Skin\DJ Console Mk2\BtnHideAsioBckgrnd.ggff
--A-- 48951 03/04/2014 Skin\DJ Console Mk2\BtnHttpLink.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk2\BtnHwState.ggff
--A-- 19360 03/04/2014 Skin\DJ Console Mk2\BtnLineIn.ggff
--A-- 7513 03/04/2014 Skin\DJ Console Mk2\BtnLineIn2.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk2\BtnLinkVolumes.ggff
--A-- 74 03/04/2014 Skin\DJ Console Mk2\BtnMasterMute.ggff
--A-- 18689 03/04/2014 Skin\DJ Console Mk2\BtnMic.ggff
--A-- 9498 03/04/2014 Skin\DJ Console Mk2\BtnMute.ggff
--A-- 22774 03/04/2014 Skin\DJ Console Mk2\BtnOnAir.ggff
--A-- 61 03/04/2014 Skin\DJ Console Mk2\BtnOut12.ggff
--A-- 61 03/04/2014 Skin\DJ Console Mk2\BtnOut34.ggff
--A-- 21326 03/04/2014 Skin\DJ Console Mk2\BtnOutputConfig.ggff
--A-- 7927 03/04/2014 Skin\DJ Console Mk2\BtnPadlock.ggff
--A-- 7625 03/04/2014 Skin\DJ Console Mk2\BtnRadio.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk2\BtnSpkBackLeft.ggff
--A-- 68 03/04/2014 Skin\DJ Console Mk2\BtnSpkBackRight.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk2\BtnSpkFrontCenter.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk2\BtnSpkFrontLeft.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk2\BtnSpkFrontRight.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk2\BtnSpkIdBackLeft.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk2\BtnSpkIdBackRight.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk2\BtnSpkIdFrontCenter.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk2\BtnSpkIdFrontLeft.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk2\BtnSpkIdFrontRight.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk2\BtnSpkIdSubW.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk2\BtnSpkSubW.ggff
--A-- 39457 03/04/2014 Skin\DJ Console Mk2\BtnTabCenter.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk2\BtnTabCenter2.ggff
--A-- 35437 03/04/2014 Skin\DJ Console Mk2\BtnTabLeft.ggff
--A-- 39032 03/04/2014 Skin\DJ Console Mk2\BtnTabRight.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk2\BtnTestLeds.ggff
--A-- 61 03/04/2014 Skin\DJ Console Mk2\BtnUsbHub.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk2\BtnWDM.ggff
--A-- 5925 03/04/2014 Skin\DJ Console Mk2\ComboBox.ggff
--A-- 7123 03/04/2014 Skin\DJ Console Mk2\ComboBoxList.ggff
--A-- 5026 03/04/2014 Skin\DJ Console Mk2\ComboBoxListShorter.ggff
--A-- 4519 03/04/2014 Skin\DJ Console Mk2\ComboBoxListShortest.ggff
--A-- 5933 03/04/2014 Skin\DJ Console Mk2\ComboBoxSmall.ggff
--A-- 61 03/04/2014 Skin\DJ Console Mk2\ComboBoxSmallest.ggff
--A-- 52 03/04/2014 Skin\DJ Console Mk2\ComboBoxSmallestList.ggff
--A-- 8294 03/04/2014 Skin\DJ Console Mk2\ComboBoxSmallList.ggff
--A-- 3467 03/04/2014 Skin\DJ Console Mk2\ComboBoxSmallListShorter.ggff
--A-- 2175 03/04/2014 Skin\DJ Console Mk2\ComboDown.ggff
--A-- 1528 03/04/2014 Skin\DJ Console Mk2\ComboScroll.ggff
--A-- 1994 03/04/2014 Skin\DJ Console Mk2\ComboUp.ggff
--A-- 2209 12/16/2010 Skin\DJ Console Mk2\HDJSeriesSkinScript.txt
--A-- 878868 03/04/2014 Skin\DJ Console Mk2\MainDlgBckgrnd.ggff
--A-- 32209 03/04/2014 Skin\DJ Console Mk2\MainDlgPos.ggff
--A-- 9717 03/04/2014 Skin\DJ Console Mk2\SliderBalance.ggff
--A-- 63 03/04/2014 Skin\DJ Console Mk2\SliderRmxBalance1.ggff
--A-- 63 03/04/2014 Skin\DJ Console Mk2\SliderRmxBalance2.ggff
--A-- 63 03/04/2014 Skin\DJ Console Mk2\SliderRmxVol1.ggff
--A-- 63 03/04/2014 Skin\DJ Console Mk2\SliderRmxVol2.ggff
--A-- 63 03/04/2014 Skin\DJ Console Mk2\SliderRmxVol3.ggff
--A-- 63 03/04/2014 Skin\DJ Console Mk2\SliderRmxVol4.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk2\SliderSwitch.ggff
--A-- 61 03/04/2014 Skin\DJ Console Mk2\SliderT46Balance3.ggff
--A-- 61 03/04/2014 Skin\DJ Console Mk2\SliderT46Vol5.ggff
--A-- 61 03/04/2014 Skin\DJ Console Mk2\SliderT46Vol6.ggff
--A-- 9496 03/04/2014 Skin\DJ Console Mk2\SliderTalkover.ggff
--A-- 23809 03/04/2014 Skin\DJ Console Mk2\SliderVolume.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk2\SliderVolumeLarge.ggff
--A-- 63 03/04/2014 Skin\DJ Console Mk2\SliderVolumeSmall.ggff
D---- 0 07/12/2014 Skin\DJ Console Mk4
D---- 0 07/12/2014 Skin\DJ Console Mk4\.
D---- 0 07/12/2014 Skin\DJ Console Mk4\..
--A-- 52 03/04/2014 Skin\DJ Console Mk4\AboutDlgBckgrnd.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk4\AboutDlgPos.ggff
--A-- 52 03/04/2014 Skin\DJ Console Mk4\BmpCinema.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk4\Btn2in6out.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk4\Btn4in4out.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk4\BtnAboutBox.ggff
--A-- 61 03/04/2014 Skin\DJ Console Mk4\BtnAboutOk.ggff
--A-- 15032 03/04/2014 Skin\DJ Console Mk4\BtnAsio.ggff
--A-- 81 03/04/2014 Skin\DJ Console Mk4\BtnBatteryState.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk4\BtnBlueTooth.ggff
--A-- 3844 03/04/2014 Skin\DJ Console Mk4\BtnCheck.ggff
--A-- 2254 03/04/2014 Skin\DJ Console Mk4\BtnClose.ggff
--A-- 94 03/04/2014 Skin\DJ Console Mk4\BtnCrossFaderFigure.ggff
--A-- 66 03/04/2014 Skin\DJ Console Mk4\BtnHeadphone.ggff
--A-- 81 03/04/2014 Skin\DJ Console Mk4\BtnHeadphoneSwitch.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk4\BtnHelp.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk4\BtnHideAsioBckgrnd.ggff
--A-- 41739 03/04/2014 Skin\DJ Console Mk4\BtnHttpLink.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk4\BtnHwState.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk4\BtnLineIn.ggff
--A-- 60 03/04/2014 Skin\DJ Console Mk4\BtnLineIn2.ggff
--A-- 5948 03/04/2014 Skin\DJ Console Mk4\BtnLinkVolumes.ggff
--A-- 74 03/04/2014 Skin\DJ Console Mk4\BtnMasterMute.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk4\BtnMic.ggff
--A-- 4237 03/04/2014 Skin\DJ Console Mk4\BtnMute.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk4\BtnOnAir.ggff
--A-- 61 03/04/2014 Skin\DJ Console Mk4\BtnOut12.ggff
--A-- 61 03/04/2014 Skin\DJ Console Mk4\BtnOut34.ggff
--A-- 71 03/04/2014 Skin\DJ Console Mk4\BtnOutputConfig.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk4\BtnPadlock.ggff
--A-- 66 03/04/2014 Skin\DJ Console Mk4\BtnRadio.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk4\BtnSpkBackLeft.ggff
--A-- 68 03/04/2014 Skin\DJ Console Mk4\BtnSpkBackRight.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk4\BtnSpkFrontCenter.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk4\BtnSpkFrontLeft.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk4\BtnSpkFrontRight.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk4\BtnSpkIdBackLeft.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk4\BtnSpkIdBackRight.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk4\BtnSpkIdFrontCenter.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk4\BtnSpkIdFrontLeft.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk4\BtnSpkIdFrontRight.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk4\BtnSpkIdSubW.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk4\BtnSpkSubW.ggff
--A-- 18838 03/04/2014 Skin\DJ Console Mk4\BtnTabCenter.ggff
--A-- 15038 03/04/2014 Skin\DJ Console Mk4\BtnTabCenter2.ggff
--A-- 13267 03/04/2014 Skin\DJ Console Mk4\BtnTabLeft.ggff
--A-- 16858 03/04/2014 Skin\DJ Console Mk4\BtnTabRight.ggff
--A-- 67 03/04/2014 Skin\DJ Console Mk4\BtnTestLeds.ggff
--A-- 61 03/04/2014 Skin\DJ Console Mk4\BtnUsbHub.ggff
--A-- 16000 03/04/2014 Skin\DJ Console Mk4\BtnWDM.ggff
--A-- 6606 03/04/2014 Skin\DJ Console Mk4\ComboBox.ggff
--A-- 6926 03/04/2014 Skin\DJ Console Mk4\ComboBoxList.ggff
--A-- 4950 03/04/2014 Skin\DJ Console Mk4\ComboBoxListShorter.ggff
--A-- 4469 03/04/2014 Skin\DJ Console Mk4\ComboBoxListShortest.ggff
--A-- 8563 03/04/2014 Skin\DJ Console Mk4\ComboBoxSmall.ggff
--A-- 5437 03/04/2014 Skin\DJ Console Mk4\ComboBoxSmallest.ggff
--A-- 4135 03/04/2014 Skin\DJ Console Mk4\ComboBoxSmallestList.ggff
--A-- 9360 03/04/2014 Skin\DJ Console Mk4\ComboBoxSmallList.ggff
--A-- 5329 03/04/2014 Skin\DJ Console Mk4\ComboBoxSmallListShorter.ggff
--A-- 1340 03/04/2014 Skin\DJ Console Mk4\ComboDown.ggff
--A-- 679 03/04/2014 Skin\DJ Console Mk4\ComboScroll.ggff
--A-- 1343 03/04/2014 Skin\DJ Console Mk4\ComboUp.ggff
--A-- 3627 12/16/2010 Skin\DJ Console Mk4\HDJSeriesSkinScript.txt
--A-- 507668 03/04/2014 Skin\DJ Console Mk4\MainDlgBckgrnd.ggff
--A-- 47092 03/04/2014 Skin\DJ Console Mk4\MainDlgPos.ggff
--A-- 63 03/04/2014 Skin\DJ Console Mk4\SliderBalance.ggff
--A-- 13773 03/04/2014 Skin\DJ Console Mk4\SliderRmxBalance1.ggff
--A-- 13773 03/04/2014 Skin\DJ Console Mk4\SliderRmxBalance2.ggff
--A-- 3779 03/04/2014 Skin\DJ Console Mk4\SliderRmxVol1.ggff
--A-- 3779 03/04/2014 Skin\DJ Console Mk4\SliderRmxVol2.ggff
--A-- 3779 03/04/2014 Skin\DJ Console Mk4\SliderRmxVol3.ggff
--A-- 3779 03/04/2014 Skin\DJ Console Mk4\SliderRmxVol4.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk4\SliderSwitch.ggff
--A-- 61 03/04/2014 Skin\DJ Console Mk4\SliderT46Balance3.ggff
--A-- 61 03/04/2014 Skin\DJ Console Mk4\SliderT46Vol5.ggff
--A-- 61 03/04/2014 Skin\DJ Console Mk4\SliderT46Vol6.ggff
--A-- 2651 03/04/2014 Skin\DJ Console Mk4\SliderTalkover.ggff
--A-- 63 03/04/2014 Skin\DJ Console Mk4\SliderVolume.ggff
--A-- 64 03/04/2014 Skin\DJ Console Mk4\SliderVolumeLarge.ggff
--A-- 63 03/04/2014 Skin\DJ Console Mk4\SliderVolumeSmall.ggff
D---- 0 07/12/2014 Skin\DJ Console RMX
D---- 0 07/12/2014 Skin\DJ Console RMX\.
D---- 0 07/12/2014 Skin\DJ Console RMX\..
--A-- 52 03/04/2014 Skin\DJ Console RMX\AboutDlgBckgrnd.ggff
--A-- 64 03/04/2014 Skin\DJ Console RMX\AboutDlgPos.ggff
--A-- 52 03/04/2014 Skin\DJ Console RMX\BmpCinema.ggff
--A-- 67 03/04/2014 Skin\DJ Console RMX\Btn2in6out.ggff
--A-- 67 03/04/2014 Skin\DJ Console RMX\Btn4in4out.ggff
--A-- 64 03/04/2014 Skin\DJ Console RMX\BtnAboutBox.ggff
--A-- 61 03/04/2014 Skin\DJ Console RMX\BtnAboutOk.ggff
--A-- 20613 03/04/2014 Skin\DJ Console RMX\BtnAsio.ggff
--A-- 81 03/04/2014 Skin\DJ Console RMX\BtnBatteryState.ggff
--A-- 67 03/04/2014 Skin\DJ Console RMX\BtnBlueTooth.ggff
--A-- 3951 03/04/2014 Skin\DJ Console RMX\BtnCheck.ggff
--A-- 2254 03/04/2014 Skin\DJ Console RMX\BtnClose.ggff
--A-- 94 03/04/2014 Skin\DJ Console RMX\BtnCrossFaderFigure.ggff
--A-- 66 03/04/2014 Skin\DJ Console RMX\BtnHeadphone.ggff
--A-- 81 03/04/2014 Skin\DJ Console RMX\BtnHeadphoneSwitch.ggff
--A-- 64 03/04/2014 Skin\DJ Console RMX\BtnHelp.ggff
--A-- 64 03/04/2014 Skin\DJ Console RMX\BtnHideAsioBckgrnd.ggff
--A-- 64614 03/04/2014 Skin\DJ Console RMX\BtnHttpLink.ggff
--A-- 64 03/04/2014 Skin\DJ Console RMX\BtnHwState.ggff
--A-- 26958 03/04/2014 Skin\DJ Console RMX\BtnLineIn.ggff
--A-- 15979 03/04/2014 Skin\DJ Console RMX\BtnLineIn2.ggff
--A-- 5377 03/04/2014 Skin\DJ Console RMX\BtnLinkVolumes.ggff
--A-- 74 03/04/2014 Skin\DJ Console RMX\BtnMasterMute.ggff
--A-- 19257 03/04/2014 Skin\DJ Console RMX\BtnMic.ggff
--A-- 3865 03/04/2014 Skin\DJ Console RMX\BtnMute.ggff
--A-- 67 03/04/2014 Skin\DJ Console RMX\BtnOnAir.ggff
--A-- 61 03/04/2014 Skin\DJ Console RMX\BtnOut12.ggff
--A-- 61 03/04/2014 Skin\DJ Console RMX\BtnOut34.ggff
--A-- 71 03/04/2014 Skin\DJ Console RMX\BtnOutputConfig.ggff
--A-- 67 03/04/2014 Skin\DJ Console RMX\BtnPadlock.ggff
--A-- 66 03/04/2014 Skin\DJ Console RMX\BtnRadio.ggff
--A-- 67 03/04/2014 Skin\DJ Console RMX\BtnSpkBackLeft.ggff
--A-- 68 03/04/2014 Skin\DJ Console RMX\BtnSpkBackRight.ggff
--A-- 67 03/04/2014 Skin\DJ Console RMX\BtnSpkFrontCenter.ggff
--A-- 67 03/04/2014 Skin\DJ Console RMX\BtnSpkFrontLeft.ggff
--A-- 67 03/04/2014 Skin\DJ Console RMX\BtnSpkFrontRight.ggff
--A-- 64 03/04/2014 Skin\DJ Console RMX\BtnSpkIdBackLeft.ggff
--A-- 64 03/04/2014 Skin\DJ Console RMX\BtnSpkIdBackRight.ggff
--A-- 64 03/04/2014 Skin\DJ Console RMX\BtnSpkIdFrontCenter.ggff
--A-- 64 03/04/2014 Skin\DJ Console RMX\BtnSpkIdFrontLeft.ggff
--A-- 64 03/04/2014 Skin\DJ Console RMX\BtnSpkIdFrontRight.ggff
--A-- 64 03/04/2014
geposted Sat 12 Jul 14 @ 3:10 pm
DJ PhatsoPRO InfinityHercules Support TeamMember since 2005
As suggested on the driver download page, did you try using a powered USB hub between the computer and the console?
geposted Mon 14 Jul 14 @ 8:53 am
Yes I did - all that i described was with a self powered hub
geposted Mon 14 Jul 14 @ 9:13 pm
Can you get that message again? Is the missing files specifically named?
Can you post a picture of Device Manager once the console is connected? The focus needs to be on the components named in the following document:
http://ts.hercules.com/faqs/eng/her_eng_00350.pdf
And how about the LEDs of the console ? I presume they are flashing ?
BTW, does the console still work on another computer, like your old one?
geposted Tue 15 Jul 14 @ 6:29 am
Here is the kicker, it was a usb cable issue in my case try a different cable into the computer.
geposted Mon 28 Jul 14 @ 10:59 pm
Hello can some one help me out on my (DJ Console RMX ) before it works for 20min and stop but now, only the the blue Led Light blinking no stopping,,,,,,,,,,,,
Can some help me with the problem am having Pls,,,,,...................... Thanks ( DJ Teddy )
geposted Sat 18 Oct 14 @ 8:23 pm
i have same ´problem trying with a new laptop msi
cant detect hercules remix windows 8 64bit ram 12g i7 4720 cpu 2.60
hercules only on my window 7 works but don luck on my new machin windows 8
hercules is now flashed with new firmware but still dont have luck
geposted Fri 11 Sep 15 @ 11:58 pm
Since it works properly on your Win 7 computer, be sure to install the latest drivers and apply the latest firmware there before trying to use it on your Win 8 PC. And as suggested on the drivers download page, a powered USB hub might also be necessary for your DJ controller to be recognized and used properly on recent computers featuring USB 3.0 ports.
Try this and let us know.
geposted Mon 14 Sep 15 @ 1:15 pm
