Topic: Automix auto save
If I use a playlist I already saved and added or changed it, it automatically saves. Get rid of this ASAP please. Screwed up my playlists and now I have to do them over again.
geposted Sun 29 Jun 14 @ 2:41 pm
Don't forget next time to remove what you don't need, but I think there is an option for auto remove somewhere, read the manual...
It has nothing to do with autoremove. The playlist simply got overwritten on its own. Not good. I'm on 1845.
Automix also needs "save as"
prety sure theres a option to turn auto save off .. u may need to enable advanced settings to see it
turn off savePlaylist and they don't get saved unless u ask for it
I will check out that setting wickedmix.
