Topic: cbg and Cuepoints shifted (Screenshot)
I came from 7.4
It was a lot of work to put cuepoints and CBG on hundred of Songs.
Now, in 8.0 they are unfortunately shifted as You can see here:
The cuepoint was a bit more left, where You see the peak.
The first beat had to be there too.
In 7.4 this is shown correct (I have booth versions installed)
By the Way, even if I fix the CBG: After some bars the sampler (with sync-start) drifts apart from the song.
There is definitely something wrong with the CBG/Beatgrid thing...
Win 8 64bit
built 1845.699
geposted Sun 29 Jun 14 @ 5:56 pm
Quote
In version 7 there was a bug on the mp3 decoder that's fixed now.
This bug was causing random wrong silence detection on the start of the songs, and as a result it was shifting the entire track.
A new action is available that will allow you to shift all hotcues of a track together in order to place them on the right place at once.
shift_all_cues -(time)ms
It's a ball ache, I grant you, a smarter way would have been a command to snap all hotcues to the nearest beat.
Thank You Locodog
But this doesn´t solve the problem.
The loosing sync of the Sampler and Song stays a big problem,
And the move from 7 to 8 has to be easy. Who has the time to check hundreds or thousands of songs...
The new version seems to be amazing but its really necessary to fix the bug of wrong CBG of allmost a whole database.
The most important thing of DJing is abaout Timing, Rhythm and Tempo...
...Isn´t it?
Please fix this bug in the next update
