Topic: Effect button crash
Hi when I rotate through my effect and activate them the system crashes once I get to about the 4th effect. Any help?
geposted Mon 30 Jun 14 @ 9:58 am
Must be an effect that is not compatible with V8.
Could you try to figure out if it is a specific or always the same effect that causes the crash?
Thanks PachN
I am looking into that right now. I did go in and delete effects I know are not good such as clipbank and Sonique and a couple of others and it hasn't crashed since I will report back.
