Topic: Folder Lag?
Apologies if this has been asked, but I couldn't find an answer.
When I try to open either my "Music" or "Karaoke" folder, which has 3000+ and 16000+ songs in each, respectively, it takes several minutes for the files to load. They are kept on an external drive. If I copy these files onto my internal HD would they most likely be accessed quicker, or is this normal?
Thank you - VDJPro8 is absolutely AMAZING. Great job, guys!
geposted Mon 30 Jun 14 @ 10:07 am
Could be normal if the external hard disk is plugged on USB2.0, but I recommend to organize your folders with 3000 (limit) each folder to speed up you browsing.
