Topic: Minor effect gui error
Win 1872.705
Seems only to be the echo effect, when several guis are open the echo gui doesn't include a close button (If I closed the other 2 [reverb, flanger] in this picture the dock button will also vanish)
http://tinypic.com/r/2m47ev8/8
geposted Wed 02 Jul 14 @ 5:34 pm
Cant reproduce it here. What is your screen resolution ? And i doubt that its something related to a particular effect, It could be just depending on the order you dock the effects, but again, i tried to reproduce it and cant.
1280 * 800 I too struggled to figure a reproduction method, but it has happened more than once, I'll try again
*Edit try this*
Beat grid, distortion, reverb echo,
reverb should lose its close button once echo opens
Nope all good here, and i forced1280x800 from settings too..
Is this skin related ? I tried with the VirtualDJ 2 decks one.
Edit.. wrong pics..
All docked..
Echo undeocked
The only thing i can see, is that glitch with the pin buttons not getting the same position to all of them, (which could be the bug actually), but i never lose them.
I'm sorry I forgot to mention '4 deck skin' (and 6 decks too oddly)
2 deck appears ok for me too
Actually 2 deck errors too with beat,grid distortion, reverb, echo and flanger
It appears to be in some circumstances ( what was on the bottom when it was 1 stack of effects, when it becomes 2 stacks the error happens to what was bottom
http://tinypic.com/r/2dujvdi/8
It might just be me, but I don't think it is
It certainly has to do with the available Browser height, but still unable to reproduce it. Having the skin semi-maximized or maximized makes any difference ?
Edit, ah it happens with the 2 decks skin too ? Well..hmm.. no idea :(
Skin is maximized, must be my crappy GFX chip, struggling to keep up, it is does correlate when a stack gets resized in width then get separated into 2 stacks,
I can't say much else I can reproduce it every time to my method, you can't it must be my end at fault.
