Hello!
I'm a DJ and also a digital artist (illustrator)
Well, I know it is strange to say that, but my controller
is the most uncommon thing in a DJ environment!
I use the same tool that I use to draw on the computer:
- a pen tablet wacom
But since the lounch of VDJ8, my tablet stopped working.
VDJ doesn't recognizes its inputs anymore.
Outside VDJ it works fine (Windows 7)
But inside VDJ, it does nothing to the faders and knobs :(
It should work exactly like a mouse, but the pen clicks don't respond.
Well, only to inform, the function keys, that are the shortcuts
buttons I use to configure on the tablet for every program
saves me a lot of work inside all softwares, and VDJ is no different!
They work ok, and I use them to combo actions in one single key like
renaming, making loops, and setting cue points, that is why I use it.
Well, I hope you guys might check that out to confirm the issue.
I'd really appreciate that :D
Thank you,
Carlos Alberto Andres
Thank you,
geposted Thu 03 Jul 14 @ 1:16 pm
I also have this problem most frustrating
geposted Wed 07 Oct 15 @ 2:09 pm
I think I have found the problem. It should be working in the next update.
geposted Mon 19 Oct 15 @ 8:28 am
