Forum: Old versions
Topic: Stop songs beat batching
How do I switch the function OFF to beat match??
So annoying
Thanks
geposted Fri 04 Jul 14 @ 1:55 pm
I also have this happening.
When I load a song on Deck A and Deck B. I start playing Desk A, which is 80 bpm. Deck B has a song that is at 100 bpm. I have the fader to Deck A. When I press play on Deck B, it will automatically adjust it's bpm to Deck A.
How does one disable this?
Don't mean to jump on your thread, but you seem to be talking about the same thing I am.
Thanks!
-John
There's an autobeat sync option. Find it in the options and turn it off.
Thanks for the reply. I found an option called "autoBPMMatch" and I have that set to "no." This does not fix the issue though.
I have autoKey also set to "no."
Any other ideas?
I actually just found it, and will let anyone who finds this thread know the solution. There is a little circle next to the Sync button for the skin I have. When I click that a menu pops up. Once this menu pops up, I turned off "Smart Play."
Now, all is good.
-John
