Topic: Close VDJ protection isn't sensitive enough
*Bugger this was supposed to be in bug report* [MOVED - DAN]
This is idiot proofing idiot proofing
but the security that asks 'Music is playing, are you sure you want to turn VDJ off?' isn't sensitive when using lower up fader levels
I'm experimenting with logarithmic faders and at levels below 45% VDJ (quiet but audible) VDJ won't initiate the switch off security, I only know this as I have a keyboard command that uses Alt & F4,
I'm just about try quad and linear faders.
*10% for linear, 30% for quad faders*
Also it takes no heed as to a sample playing being music
geposted Sat 05 Jul 14 @ 8:18 am
Thanks Dan
Same goes for the sandbox.
The sandbox should only work if just 1 track is playing and/ or 2nd Vol Fader down.
But sandbox could also be activated if the 2nd vol fader is a bit up (just like locodog said).
