Topic: 3 -5 sec freeze
This is occuring every once in a while but mostly when transitioning tracks from one deck to the other. The program will momentarily freeze for a few seconds then go back to normal. Any help?
geposted Sun 06 Jul 14 @ 2:08 am
Try to reinstall the software and delete allthe files (don't forget to save your database and the setting files) than try to log you into VDJ and make the update.
Thanks a mil Jox. So far its not asking to use the updated version hopefully meaning Im using the latest update. Wont be able to tell if its stopped the freezing until I run it for a few hours. :)
Which version do you have ?
