Topic: Track Editor wish
geposted Sun 06 Jul 14 @ 8:34 am
You can do this with action POI's I think
Yes in POI you can add actions too, like pitch etc..
that don't work.....Need pitch shift in TRACK CLEANER, to censor.
yes it will work but what you want to do is drop the key not the pitch.
