Topic: Touchwheel scrolling in reverse direction
Hi,
When the song is playing in reverse direction (VDJ script action : reverse) the jogwheel is also in reverse.
When you are playing normal, using the touchwheel clockwise the song goes forward and counter-clockwise the song goes backwards. As it should.
When you are playing reverse, using the touchwheel clockwise the song goes backwards and counter-clockwise the song goes forward. This is wrong.
The graphical representation follows this behaviour, so when in reverse mode it spins the other way on screen then what you are doing on the controller.
In VDJ7 no matter the direction of the song playing using the touchwheel clockwise would always make the song (and graphic) go forward.
I was unable to find a setting for this. It could probably be fixed with editing the VDJ script action that checks for the direction the song is played ?
Note : I am using the EKS XP10 controllers with the internal device definition and mapping.
geposted Sun 06 Jul 14 @ 1:31 pm
Agreed. Reporting.
In the meantime you can have...
reverse ? param_multiply -1 & touchwheel : touchwheel
Just out of curiosity I tried pitch bend when in dump mode and that works in backwards fashion too, - speeds it up + slows it down
sorry for the delay, but I can confirm that using the script line is working.
Reverse play now also reverses the jog direction.
This script should be added to action associated with the mapper KEY : JOG
Note : default action in VDJ 8.0.1910 still is wrong :-)
