Hi, using VDJ8, is it possible to highlight songs with different colours that are in the playlist or sidelist view?
geposted Tue 08 Jul 14 @ 4:16 am
Yes you can, but the only way to do it currently is to manually change the colour via the Tag Editor - which will then be permanently assigned to that track unless you change it back.
There's no way to highlight tracks temporarily, or based on certain criteria (such as a particular genre being red for example). No rule/filter based auto colour assignments.
geposted Tue 08 Jul 14 @ 5:17 am
