Topic: History-Playlist order
Hi,
I wanted to recall my playlist in "history" from the party I've played last weekend with vdj8 and it wasn't in the right order anymore...
I have looked for the problem but can't seem to find it.
I did try "play time" but he still won't do it.
geposted Wed 09 Jul 14 @ 3:30 pm
So, what does it do when you select "play time"?
Thx for your soon reply!
It changes, but not in the order that i played them originally.
It's a pre-made set that i use for this specific crowd i play for.
I re-played the list (cause i have backup lists on paper) when i finished, i immediately checked my history but yet again they were all out of play-order and i can't put them in the right order anymore.
The times are not in chronological order?
If you are speaking of playlists (not history files), do a rightclick on the column header and choose "reset sort order".
I'm embarrassed!
But problem solved! It was playtime indeed.
Thanks!
No problem, glad everything worked out for you.
