Topic: bpm changing on its own???
anyone else experience bpm changing on its own? very weird, 1st time that happened to me (confused)
btw im on a macbook pro, was using a wego2 at the time of this ghost bpm change :p
geposted Wed 09 Jul 14 @ 4:42 pm
Does the BPM change when u load the track ?
autoBPMmatch setting is set to Smart by default. Try to change it to No.
that is set to no already. i have no clue what went wrong here.
Can you reproduce it at will ? Does the BPM change when PLAY is pressed ?
I've had VDJ 1/2 a couple of bpms (while playing) on the first play of tracks that were pre (batch) analysed, but it has only happened once or twice but I have bpm double and 1/2 mappings (Thanks again devs for eliminating the rounding error)
Was your bpm change a 1/2 or double or was it something else? Any we are talking aou4t a bpm change and not a pitch change?
the original bpm is 125 and would slide to 131+ and no cant do it at will but it did happen about 3x.
Im having this same issue .... im so confused i even rest back to factory 4 times and it still giving me the same thing different bpms and i have a huge library and i cant go back to rebpm my files it will take so long ill lose out .... is there any help with this please
You read that and tried it?
