When I start with the automix editor everything works fine, but if I change the order, or add a new song, then it doesn't work so well. The green line that indicates playing spot does not work right, the stop control does not stop, it starts playing at the beginning, and sometimes the blue navigation bar does not work either, so you can't expand the bar or move it to the area you want to work on.
Virtual dj8 build 1872.712
Windows 8.1
Numark Mixdeck Quad
Windows 8.1
Numark Mixdeck Quad
geposted Thu 10 Jul 14 @ 1:40 am
