Topic: VDJ closes even if asked
A german user reported, that VDJ will close if you press the X button a 2nd time after being asked "a track is still playing....".
Happens too, if you do a double-click.
I can confirm that.
It should not close when the dialog box is open. Maybe it is a modal dialog?
geposted Sat 12 Jul 14 @ 2:55 am
I can also confirm this.
same for me too
This behavior is the same as the load command, where using it a second time confirms the dialog so that the action can be used from controllers as well.
Why not two different options / behaviors ?
Yes, two different behaviours would be better.
It's legit for the load dialog, but not for the close dialog.
