<map value="NAV_DOWN" action="set "fx" 2" />
<map value="NAV_UP" action="set "fx" 1" />
var_equal "fx" 0 ? browser_scroll : var_equal "fx" 1 ? deck 1 effect active ? deck 1 effect slider 2 : nothing : deck 2 effect active ? deck 2 effect slider 2 : nothing Original Mapping
var_equal "fx" 0 ? browser_scroll : var_equal "fx" 1 ? deck 1 effect active ? deck 1 effect slider 2 : deck 1 loop ? param_bigger 1 ? loop_half : loop_double : var_equal "fx" 2 ? deck 2 effect active ? deck 2 effect slider 2 : deck 2 loop ? param_bigger 1 ? loop_half : loop_double this part don´t work on deck 2 i don´t now why plz help
geposted Sat 12 Jul 14 @ 3:30 pm
What exactly are you trying to do, cause the action doesnt make much sense.
geposted Sat 12 Jul 14 @ 10:36 pm
On deck 1 everything works as it should. On deck 2 only to effect active. If no effect is active and a loop has been set, I would like half or double with the endless encoder.
geposted Sun 13 Jul 14 @ 4:52 am
This should work fine...
var_equal "$fx" 0 ? browser_scroll : var_equal "$fx" 1 ? deck 1 effect active ? deck 1 effect slider 2 : deck 1 loop ? loop_double : nothing : deck 2 effect active ? deck 2 effect slider 2 : deck 2 loop ? loop_double : nothing
and use global variabled $fx instead of deck local.
geposted Sun 13 Jul 14 @ 7:19 pm
yes thx
geposted Mon 14 Jul 14 @ 12:55 pm
