Forum: VirtualDJ Skins
Topic: My naff gfx card
My gfx is pretty useless with 3D acceleration, because of this the rhythm wave(s) is almost useless on 4 & 6 deck skins, what I've been doing is putting all 4 decks into a long loop just so the wave is highlighted for a moment and I can see what's going on.
2 deck skins work no problem, but on the 4 & 6 decks even just showing left & right deck waves are so dark they are just about invisible (Scratch waves are visible but there's no visible CBG and the markers for cues are tiny)
So I'm wanting a work around,
If possible I'd like to panel the browser and in that space have 3 rhythm wave windows (2 decks per window) but I'm not sure the waves will show clearly
I'd go for 6 scratch waves horizontally if I could see the CBG and cue markers.
Any other ideas,
geposted Sun 13 Jul 14 @ 11:19 am
I have two:
1. Buy a better machine ;-)
2. Buy..... Ah you know that one ;-)
Lol
geposted Sun 13 Jul 14 @ 2:39 pm
I tried V8 on my second machine that has better GFX (this one has an actual card and not a chip!) But it has critically low ram (1 gig on vista ROFL) so nothing works to even check (4GB on its way in the post)
Didn't you manage scratchwave with CBG in one of your skins?
geposted Sun 13 Jul 14 @ 3:29 pm
