Hi I am using VDJ 8.00 PC build 1872.722 with the default VDJ 4 Deck Skin and the Denon MC6000 MK1 controller.
I cannot seem to set the deck 1 and 2 Filters to zero.
Deck 1 sets itself to <816hz and Deck 2 <20hz while the remaining decks stay at 0 or off!
I manually reset them on the interface, but after shutting down and restarting the PC they reset back.
EDIT: - IT SEEMS THAT ON THE MC6000 MAPPING EFFECTS BUTTON 4 ON EACH DECK ARE MAPPED TO A FILTER BUTTON
https://virtualdj.com/forums/187106/VirtualDJ_8_bug-report_Forum/Problem_with_Virtual_8___Denon_MC_6000_%28Original%29.html?search=eq+filter&page=2
Just have to make sure that the buttons are central before starting a gig!!
Thank you.
Thank you.
geposted Sun 13 Jul 14 @ 1:54 pm
If you search for 'MC6000' and 'filter' you'll find a post by djdad that details how to add an oninit string to your mapping that resets /turns off the filters.
geposted Sun 13 Jul 14 @ 2:31 pm
thank you....
You can use ONINIT - Simply add this key to your controller mapping if it's not already present and then add the following:
deck 1 filter_active off & deck 2 filter_active off
Or for four decks:
deck 1 filter_active off & deck 2 filter_active off & deck 3 filter_active off & deck 4 filter_active off
NOTE: If ONINIT is already mapped, add the above mapping to the end of the existing one with & before 'deck 1 filter_active off'
I think I will remap the 4 FX keys and buttons to something more useful - thanks again.
geposted Sun 13 Jul 14 @ 6:04 pm
