Hi everybody! How can I map my DJM850 in virtual dj 8.1? (Windows 7) I'm using two Pioneer CDJ400s on channel 1 cd/line and 2 cd/line, vdj deck 3 on channel 3 usb5/6, vdj deck 4 on channel 4 usb7/8)
I'm on the controller's page in settings, and when I touch my TRIM the option comes up but I can only set it up for one channel at a time. As well as the equalizers low, mid and high and the volume fader. When I try to set it up for channel 2 it replaces the first setting. How can I set up the multiple channels?
Thanks in advance.
Thanks in advance.
geposted Mon 14 Jul 14 @ 2:52 pm
Pioneer DJM 850 is not a natively supported device, but you can use one of the available custom definitions https://virtualdj.com/addons/controllers.html?category=best&order=default&search=pioneer+djm (if not using one of them already)
You dont have to use deck x before the action. Just assign the TRIM as ..gain and all 4 TRIM knobs will get the same action (assuming that the knobs are properly defined in the definition)
geposted Mon 14 Jul 14 @ 4:29 pm
