Topic: Button Scripts
What would be the button scripts for the following be please?
VideoAudioOnlyVisualization=None
VideoAudioOnlyVisualization=Milkdrop8
geposted Wed 16 Jul 14 @ 7:23 am
If this isn't possible would someone just let me know please?
You can use the action setting 'settingname' 'settingvalue' to change or query any setting from the Options.
So you can have ..
setting 'VideoAudioOnlyVisualization' 'Milkdrop8' ? setting 'VideoAudioOnlyVisualization' 'no' : setting 'VideoAudioOnlyVisualization' 'Milkdrop8'
You're a superstar!
Thank you very much. That's resolved the key issue that was holding me back from using VDJ8 live.
I did struggle with it at first, but then realised the the spelling was incorrect:
setting 'VideoAudioOnlyVisualisation' 'no'
setting 'VideoAudioOnlyVisualisation' 'MilkDrop8'
Thanks again
Roy
