Topic: Pitch range per deck
Is it possible to change the pitch range for each deck separately?
geposted Thu 17 Jul 14 @ 8:58 am
No.
locodog wrote :
No.
Why only No? There isn't any mapping or solution to do?
It's not possible, because pitchRange is a settings, that does only take 1 value.
It like, your are not able to have different skins for deck A and B.
PachN wrote :
It's not possible
But it could,
If skinners could set an action such as "deck left pitch_lock". But actually they can't.
You should submit this in the "Wishes and new features" forum.
In serato dj, itch, scratch live, serato dj intro... you have this option, why can't we have it in VDJ8 too?
Because VDJ thinking process is limited, im starting to see for every plus there is also a minus. I also notice the users are more developers the the staff. Effects, skins alot of the good things are done by users. but you strip away the user developed options VDJ aint all the hype it puts itself to be.
Maybe we should all have a word to say for developping and upgrade the software.
To make a store in the software to download skins, effects and mappings without going on the website to download them individually.
