Topic: Automix rescanning tracks
When I load tracks from a virtual folder into the automix list, some of the tracks get rescanned.
All of my music has be analysed for bpm etc, so I don't know why it's doing this.
geposted Fri 18 Jul 14 @ 4:44 am
If your database was converted from v7 to v8 version 8 will reanalyse the track only the first time it's being loaded with v8.
After that it should not reanalyse the track anymore.
I analysed ALL my tracks when I installed vdj8.
I did this so that vdj would not have to analyse them again.
So do I still need to load all my tracks onto decks so they wont be reanalysed.
Can you describe how or what is being displayed when these tracks get reanalysed?
When I load a bunch of songs into the automix list some of them get the red colour move over them, like when they are being analysed for bpm etc.
My worry is that while it is doing this it pushes my cpu usage up to 100%.
It is also analysing them in the browser window at the same time.
I have virtual folders setup to show scanned and unscanned tracks, and there are no track that need to be scanned.
