I noticed today after watching your "How To Video" "VirtualDJ 8 - Sampler Recording"
After creating a few Test Samples(MP3 Format) from sound effect Files within Audacity,The Samples I created sounded perfect when played back in Audacity. but after loading them into Version 8 build 1878.729 I noticed A POPPING Noise at the end of EVERY Sample I made. Then I wanted to make sure it was version 8, I loaded up V7.4 and loaded the same Samples into it and they ALL played perfect with NO Popping noise. Can you please let me know if I am doing something wrong or is there A BUG in the software that is causing this problem? Thank you and I look forward to hearing from you.
geposted Fri 18 Jul 14 @ 11:08 am
