A 4 Decks swap skin version with graphics based on the Default ver 8 skin.
Offers a 4X2X2 Pads matrix with actions based on the default mapper of Pioneer DDJ-SR
Audio & Video Mode
Visit http://www.virtualdj.com/forums/189874/VirtualDJ_Skins/VirtualDJ_8_-_4_Decks_Swap_-_Pads_version.html for further details or comments
Enjoy
Audio & Video Mode
Enjoy
geposted Sun 20 Jul 14 @ 9:36 am
Audio & Video Mode
Enjoy
Audio & Video Mode
Enjoy
Muchas gracias DjDad
geposted Sun 08 Feb 15 @ 9:49 am
Your really awesome. Thanks a lot
geposted Sat 16 May 15 @ 5:40 am
Might add all your skin 8 Effect button pad the master think is important and the only thing missing in all versions of pioneer for use...
geposted Thu 24 Sep 15 @ 4:15 pm
could create the same skin 4 deck pad with version sb? in short to create the skin version of sb you have and that they can use 4 pads? it would be excellent
geposted Sat 26 Sep 15 @ 7:33 am
can you make a vu meter for the broadcast stream its helpful strea,ming live knowing your connected with out having to go to settings is that possible
geposted Fri 14 Apr 17 @ 6:27 pm
I'm looking for a skin for the Pioneer DDJ-SR2. I've had this Controller and have not seen anything on this site. Can anyone help?
geposted Sun 17 Mar 19 @ 3:17 am
A skin for the SR2, or a skin that looks like the SR2?
If it's a skin for the SR2 then you can use any skin with any controller. A skin does not have to look like the controller in order to function.
geposted Sun 17 Mar 19 @ 11:35 am
