This is a workaround to build your own skin based on a large library of small resized and repositioned windows., all chosen from a menu.
the project is still in Beta phase as some unresolved bugs in the Skin engine makes it actually unusable under real circumstances.
Please read the relative topic before using this. http://www.virtualdj.com/forums/187973/VirtualDJ_Skins/_BETA__Skin_Builder_-_Version_8.html
Have fun !!!
Update ver 0.2
- Fixed Deck Scratchwaves (horizontal & vertical)
Have fun !!!
Update ver 0.2
geposted Sun 20 Jul 14 @ 9:50 am
 Can't resize them and have some others the same way.
       geposted Tue 26 May 15 @ 9:36 am
          the updates are planned for virtual dj 8.2 ?
    geposted Sun 25 Sep 16 @ 12:21 pm
          Why cant i download vdj8 skin builder
    geposted Sun 25 Sep 16 @ 4:18 pm
          It's for LE, Plus and Pro license holders only.
    geposted Sun 25 Sep 16 @ 4:23 pm
I will check for bugs and minor updates, but there wont be any major update (e.g. Pads implementation) unless I (or others) find a way to export/load/save skins/projects with Skin Builder.
BTW, Its in my plans to learn C++ and create a Plugin for that, but this will probably take months (if not more lol), so if anyone knows C++ well enough and is willing to help, let me know
geposted Mon 26 Sep 16 @ 3:38 pm
          Thank you for your answers djdad  ;)
    geposted Tue 27 Sep 16 @ 11:36 am
