Forum: Addons
Addons comments
Topic: VDJ8 Pads (iPad)
Sampler trigger for your iRemote and Virtual DJ 8.
12/05/14 - Version 1.0.0
- 16 Trigger Buttons
- Bank Select
- Play Mode (On/Off / Stutter / Unmute / Hold)
- Volume Control
- Output Select (Master or Headphones)
Known Issue:
If you activate (for example) Slot 8 in one bank. If you then switch to another bank (where slot 8 is empty) the button remains lit, the button will be unresponsive until you return to a bank with something in Slot 8.
If your banks all have 16 samples in then you will not see this issue.
Feedback and comments here: http://www.virtualdj.com/forums/187104/VirtualDJ_Skins/_NEW___VDJ8__VDJ8_Pads_(iPad).html
geposted Sun 20 Jul 14 @ 9:55 am
