18 Professional profiles for the EQ10 plugin, presets like Dance, Rock etc.
To install copy the EQ10.dat file to your Documents\VirtualDJ\Plugins\SoundEffect folder.
WARNING: This will overwrite your existing presets.
Please also note that this addon requires the EQ10 plugin.
geposted Sun 20 Jul 14 @ 10:22 am
I've just tried this, but when I click the profiles button nothing happens?
geposted Wed 03 Aug 16 @ 6:23 pm
As stated in your other thread, you need to assign the plugin as a master effect. How to do this is in the user manual.
geposted Wed 03 Aug 16 @ 7:40 pm
Where can i get the EQ10 plugin. I'm not finding that.
Sorry my bad engglish.
geposted Wed 15 Feb 17 @ 1:43 am
You can find it here:
https://virtualdj.com/plugins/?addonid=16704
geposted Wed 15 Feb 17 @ 9:44 am
Now i have a cuestion.
I have installed the plugin and let it work.
When i move the faders of the EQ, the sounds compress, and the dynamic range begin shorted. This is not functionally for me, because i use in replacement of an 15 band graphic eq on small parties where don't use rack, only amplified speakres with no eq.
If u have a solution or any idea, i will listen.
thanks in advance
sorry bt my bad english, i'm from argentina and no use automatic translation because is poor and buggy.
thanks in advance
geposted Sat 18 Feb 17 @ 1:38 am
This is probably because VDJ has a built in limiter, which protects from overload distortion, and you are moving the EQ faders too far, activating the limiter.
geposted Sat 18 Feb 17 @ 10:00 am
EQ10 profiles do not work on EQ10 on mac it shows no profiles. please help?
geposted Sun 18 Oct 20 @ 4:02 pm
