Forum: Addons
Addons comments
Topic: Profiles for EQ10
18 Professional profiles for the EQ10 plugin, presets like Dance, Rock etc.
To install copy the EQ10.dat file to your Documents\VirtualDJ\Plugins\SoundEffect folder.
WARNING: This will overwrite your existing presets.
Please also note that this addon requires the EQ10 plugin.
geposted Sun 20 Jul 14 @ 10:22 am
I've just tried this, but when I click the profiles button nothing happens?
geposted Wed 03 Aug 16 @ 6:23 pm
As stated in your other thread, you need to assign the plugin as a master effect. How to do this is in the user manual.
geposted Wed 03 Aug 16 @ 7:40 pm
Where can i get the EQ10 plugin. I'm not finding that.
Sorry my bad engglish.
geposted Wed 15 Feb 17 @ 1:43 am
geposted Wed 15 Feb 17 @ 9:44 am
Now i have a cuestion.
I have installed the plugin and let it work.
When i move the faders of the EQ, the sounds compress, and the dynamic range begin shorted. This is not functionally for me, because i use in replacement of an 15 band graphic eq on small parties where don't use rack, only amplified speakres with no eq.
If u have a solution or any idea, i will listen.
thanks in advance
sorry bt my bad english, i'm from argentina and no use automatic translation because is poor and buggy.
geposted Sat 18 Feb 17 @ 1:38 am
This is probably because VDJ has a built in limiter, which protects from overload distortion, and you are moving the EQ faders too far, activating the limiter.
geposted Sat 18 Feb 17 @ 10:00 am
EQ10 profiles do not work on EQ10 on mac it shows no profiles. please help?
geposted Sun 18 Oct 20 @ 4:02 pm
