This is my personnal mapper from the NS7 for VirtualDJ 8 with 4 decks use.
Functions:
2 decks (1 and 3) on the CRATES button.
2 decks (2 and 4) on the FILES button.
Slip Mode on the Pitchbend - and added LED SYNC blink when it's on.
Line In function on Pitchbend +.
Controller Reinitalisation on SCROLL PUSH.
STOP on CUE button.
CUE on SYNC button.
Blink on PLAY and CUE buttons when the song is on pause.
PFL on LOAD A and LOAD B buttons for each deck.
NO headphones switch between Cue 1&2 and Master but only PFL and Master.
Master Output for the UV Meters.
CUE buttons are blinking in red colour when you click the DELETE button.
Automix function on PREPARE button.
Upgrade 1.3:
Function Master Balance on the BOOTH.
Master Balance for the Horizontal Meter.
Scratch button on when is disabled and blinkfast when enabled.
Instruction to use it in VirtualDJ8:
Simply make a copy or cut and paste the XML file into the directory C:\Users\Your computer's name\Documents\VirtualDJ\Mappers
and enjoy.
If you have any questions about the mapping, ask me them on the post i made for it:
https://virtualdj.com/forums/190802/VirtualDJ_Plugins/NS7_4_decks___Mods.html
Functions:
STOP on CUE button.
CUE on SYNC button.
Upgrade 1.3:
and enjoy.
geposted Sun 20 Jul 14 @ 10:50 am
i got to have it
geposted Sun 16 Dec 18 @ 4:57 pm
No problem - just buy a Pro license.
geposted Sun 16 Dec 18 @ 6:02 pm
because this extension can´t be downloaded I somehow Fixed it
Mapping:
creates(button)=(action) deck 1 leftdeck ? deck 3 leftdeck : on & deck 1 leftdeck
files(button)=(action) deck 2 rightdeck ? deck 4 rightdeck : on & deck 2 rightdeck
Creates button switches between decks 1 and 3
Files button switches between decks 2 and 4
Mapping:
geposted Fri 16 Feb 24 @ 1:39 pm
Yes it can, if you have the appropriate license.
geposted Fri 16 Feb 24 @ 4:19 pm
