Topic: Song loading & Manual Loops
I use custom keyboard shortcuts for loading tracks: CMD + Left arrow key & CMD + Right arrow key
I use commands verbs: deck 1 load & deck 2 load .
If i try to load the same song again, again it does not load the track - I use relative mode when play timecodes - it is the quickest way to restart the track from beginning is to reload it on deck - but vdj does not load the track again since it is already on deck - I should be able to reload the track - even though it is on is already on deck.
The second thing - not sure if it a bug or just a programmer preference:
I like to make my loops manually - vdj does not mark/highlight the track on the waveform while the manual loop is in progress - it only show after the loop is completed or the OUT loop is pressed..
geposted Sun 20 Jul 14 @ 11:52 am
Issue 1 can be avoided with ' deck 1 unload & deck 1 load '
That works - thanks..
