Forum: Addons
Topic: MULTI TouchScreen - Page: 2
Hi,
I can't find the - Mix_now button - at that Skin. Can somebody help me. I use VDJ 8.
Thanks for help
Jason
Add the mix_now action to one of the available custom buttons.
OK, thanxs...
By the way an other question:
I want to create a custom button which load the selected file from the browser as the next song to be played in the playlist.
I only find a command to load the selected file as last track at the playlist.
Best regards form Germany
Jason
There is no way to define the "position" that the track will get inside the Automix list. You can only load it at the end of it.
However, Thank you for the support...
Jason
works fine on my system
Wow i'm love with your skin ... Can u add a ipad version that fits ;)- l'll be nice ... Very nice ! Best look and options for me
Thanks very much for a brilliant skin :)
Running this on an Acer touch screen using the Numark NV.
Only two little niggles, 1:After downloading and installing v2.1 I am still told that I am running v2.0
when putting the mouse over the skin in the Interface settings, so I am really not sure which version I am using
2:The "Sampler" listing is only shown as Buttons/Icons, Is there a way to switch this to a text listing as is possible
for the track listing ?
Thanks for a brilliant skin... Phil
Great skin - love the custom buttons.
Can you tell me how to have a button that loads a video plugin on both decks at the same time?
Is there a chance you might add support for four decks in the future?
Many thanks.
Mark
Well,
I thought I was doing ok until I went live with the skin.
Windows 10 just does not sit happy with the skin and my Denon Mc6000 MK1
It just randomly freezes for no apparent reason and VDJ took ages to indicate an issue.
I am using a laptop with dual video outputs:
NVIDEA GeForce 920M
INTEL HD GRAPHICS 5500
Virtual DJ is configured to use NVIDEA GeForce 920M
Ultralatency = No
videoForceFullscreen=0
At first I thought it was my custom buttons that may have caused the issue so I removed them all but still the same, so I switched off all non essential services, firewall, windows defender, rebooted and still the same.
In the end I had to resort to removing the skin and opting for the default 4 deck skin and everything was back to normal and did a 5 hour gig flawlessly.
I have checked the windows log for any clues and it shows:
Quote :
The program virtualdj8.exe version 8.1.2857.0 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
Process ID: 174
Start Time: 01d1c27a33bc37f2
Termination Time: 110
Application Path: C:\Program Files (x86)\VirtualDJ\virtualdj8.exe
Report Id: 299f9854-2e6e-11e6-aa2b-54ee75500201
Faulting package full name:
Faulting package-relative application ID:
Quote :
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Application Hang" />
<EventID Qualifiers="0">1002</EventID>
<Level>2</Level>
<Task>101</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2016-06-09T18:15:44.434577100Z" />
<EventRecordID>332</EventRecordID>
<Channel>Application</Channel>
<Computer>VIP-TOUCH</Computer>
<Security />
</System>
- <EventData>
<Data>virtualdj8.exe</Data>
<Data>8.1.2857.0</Data>
<Data>174</Data>
<Data>01d1c27a33bc37f2</Data>
<Data>110</Data>
<Data>C:\Program Files (x86)\VirtualDJ\virtualdj8.exe</Data>
<Data>299f9854-2e6e-11e6-aa2b-54ee75500201</Data>
<Data />
<Data />
<Binary>430072006F00730073002D0074006800720065006100640000000000</Binary>
</EventData>
</Event>
Any help please as it really is a useful skin
thank you
Skin has been updated to version 3.0
- Pads support
- 4 Decks support (decks swap from the numbered buttons on the Deck info area
- New MIC/LINE IN panel (click on the OUTPUTS panel)
- New Custom knob panel (click on the FILTER panel)
- Various adjustments/fixes for 8.2
Tempted to change to this skin from "focus" because its 4 deck, is it still a custom button job for key change, what about link mode? Disappointed that the search box font is still to small and the clock is not larger. However I appreciate your excellent work, thanks
Key change : Ok will add something.
Link mode : ?? can u explain ?
Search font size. Ok will make it a bit larger.
Clock : Its large enough i think. Probably it has the larger size than all other texts in the skin
linking video to a mp3 track as in focus skin (button top right hand side)
Thats a setting in OPTIONS named as .. videoCreateLinkOnDrop
You can assign that to a custom button as well , in case you need to toggle back n forth all times.
setting 'videoCreateLinkOnDrop'
Thanks DJDad........right click on filter brings up custom button, hit edit and it edits both decks but not individually is that correct?
Could be me, 8.2 or skin , but I'm unable to link a video to mp3 even if I change back to focus skin and follow the tooltip instructions. What's wrong?
Yes that is correct. The custom knobs apply to all decks.
For your other Q, lets continue the discussion in the Focus topic.
No need got it working in focus but haven't cracked it in Multi I'm afraid. Would it be because its two screens I can link using the default screen.
22%
